I’ve been following this over on the HAMB. If I’m reading it right, you’ll need to turn the front bearing retainer about 1/4”. Based on what I did some years ago with the later Ford 4 speed o/d discussed there. A measurement from Ford Dearborn will tell you.
2 of the transmissions to bellhousing bolts will line up. You may have to drill and tap the other 2, it’s not a big deal. The input shaft length I can’t remember. May need a 1/8 or 1/4 inch shortening. That is also not a big deal, I’ve done that on T-5’s. Watch the length of the clutch splines, but that should also not be a problem.
Using the Jeep shifter on the top cover, I don’t have a clue, but it would probably be appropriate for a model A.
Anyone interested in this discussion, here’s the link.
https://www.jalopyjournal.com/forum/threads/gear-vendors-with-a-3-speed-toploader-anyone-have-it.1279511/
