Posts: 1.9K,
Visits: 195.0K
The headers will move with the engine, and it won’t move much with the FPA steady rest set up. Trying to bend those headers isn’t the answer. A dimple will work if needed. I sent you (slumlord) a pm.
Last Active: 4 Months Ago
Visits: 137.8K
The headers and the oil tube are both firmly attached to the engine so engine movement won’t affect the clearance. Going to try a bigger crowbar on the headers and if that doesn’t work I’ll address the oil tube. Thinking about loosening it and applying pressure while re tightening it it bending it.
Visits: 137.8K
Bigger crowbar got me a very small space between the header. Loosened both ends of the oil tube and put pressure on it with a bottle jack and re tightened everything. Got about .050 space. Will see how it works. Pretty sure the tube got damaged when my first wife put a rod through the side of the original block. That’s another story. .
