Last Active: 10 Months Ago
Visits: 1.1K
Can anyone tell me the difference between the water pump brackets as in how far forward/ backward the two different brackets sit. I am collecting parts and have mostly parts from a 58/59. I have so far the water pump bracket with the pump bracket, a pitman arm, the harmonic balancer add on pulley, a short nosed pump with the shallow pulley, the main rod the tie rods/ control valve/ ram connect to and finally the idler arm with the bracket, but I am unsure of the water pump bracket. I think it might be one from a 57, but I need to be sure. Also does anyone know how critical the differences are or if they can be fixed with spacers if I have the wrong one?
Visits: 3.8K
Visits: 119.5K
Hello If you check 1957 forum there is lot of info.
Last Active: 5 days ago
Visits: 113.4K
Maybe this will help. Not my parts/listing and know nothing about the seller. https://www.ebay.com/itm/325248941534
Visits: 1.1K
Thanks guys I will keep digging.
Visits: 8.4K
It would help to know what year and engine size you are working with.
Visits: 1.1K
A 272 y-block.
