Converting Manual Steering to Power
http://forums.y-blocksforever.com/Topic163277.aspx
By 58meteorranchero - 2 Years Ago
Can anyone tell me the difference between the water pump brackets as in how far forward/ backward the two different brackets sit. I am collecting parts and have mostly parts from a 58/59. I have so far the water pump bracket with the pump bracket, a pitman arm, the harmonic balancer add on pulley,  a short nosed pump with the shallow pulley, the main rod the tie rods/ control valve/ ram connect to and finally the idler arm with the bracket, but I am unsure of the water pump bracket. I think it might be one from a 57, but I need to be sure. Also does anyone know how critical the differences are or if they can be fixed with spacers if I have the wrong one?
By stuey - 2 Years Ago
this may help from J Mummert
http://www.ford-y-block.com/accessories.htm
stuey
By cos - 2 Years Ago
Hello  If you check 1957 forum there is lot of info.
Maybe this will help. Not my parts/listing and know nothing about the seller.           https://www.ebay.com/itm/325248941534
Thanks guys I will keep digging.
By Lou - 2 Years Ago
It would help to know what year and engine size you are working with.
A 272 y-block.
