What is this called? oil pump inlet tube?
Posted By B-rad 4 Years Ago
B-rad
Posted 4 Years Ago
Supercharged (921 reputation)Supercharged (921 reputation)Supercharged (921 reputation)Supercharged (921 reputation)Supercharged (921 reputation)Supercharged (921 reputation)Supercharged (921 reputation)Supercharged (921 reputation)Supercharged (921 reputation)
Last Active: 5 hours ago
Posts: 359, Visits: 1.5K
I was correct. It front and part number is 6639
Brad
Sierra Vista Arizona
1954 Lincoln Capri
Posted 3 Years Ago
Last Active: 12 hours ago
Thanks for the number.  With the basic 6639 basic part number now available, it does come up in the 1959 Ford I.D. Catalog on my end.  Without it being in the 1959 Ford illustrated catalog, that’s a tough one to find.  Might need the Lincoln parts catalog to get an exact part number.  But here’s the excerpt from the 1959 Ford I.D. catalog showing it for the Ford 239 Y engines.  If someone has a Lincoln parts catalog, then it can be determined if both the Ford Y and the LYB engines in 1954 used the same oil pump to oil pan tube.
http://forums.y-blocksforever.com/uploads/images/8f40b7d6-d1b6-4bf3-9750-4880.jpg
Robs36Ford
Posted 3 Years Ago
Posts: 93, Visits: 335.7K
This is from the 56-58 Lincoln parts book
1936 Ford 3W Coupe : 56 T-Bird 312, 47 Packard 3 speed, 40 juice brakes.
1968 Merc Cyclone FB GT 390, Getting a better front clip!
1977 Ford F-250 Supercab RWD Explorer Long box.
1976 Chev Camaro RS LT
Future rebuild : 1949 Ford F-1
Robs36Ford
Posted 3 Years Ago
From the 56-59 Lincoln Chassis book
Posted 3 Years Ago
Based on the part numbers from the Ford and Lincoln catalogs, the FYB and LYB oil pump inlet tubes are different.  There’s a good chance that the inlet tube from the 1954 239 and 256 FYB engines could be adapted or modified to fit the LYB engine with just a little bit of work.
Another option is to just modify what you have using AN hoses and fittings.  Here’s an example of what was done on a Ford Y.  A similar setup could be done on the LYB engine.
http://forums.y-blocksforever.com/uploads/images/7055ab14-bddf-4baf-9f9a-cae9.jpg
http://forums.y-blocksforever.com/uploads/images/d5141490-57cf-4f0f-91b4-7522.jpg
