Tealy64
Last Active: 5 Months Ago
Visits: 1.3K
They seem pretty beat up. Where can new ones be found?
1964 Ford F100 w/ 292 Y-block -Central Florida-
Posts: 1.4K,
Visits: 2.0K
It's an engine block coolant drain cock. If your local auto parts store can't help you, look up part # 8115 55/57 drain cock, ($5.95) at concoursparts.com. If yours opens and closes and doesn't leak, just clean it up (don't remove it). It looks like it either has grease/road grime caked on it or undercoating.
Last Active: 20 minutes ago
Visits: 39.3K
You can probably get them at your local hardware store. They are there for when you need to drain the block.
Tealy64
Visits: 1.3K
Ahh, gotcha. That makes sense. I'll give them a good scrubbing, if they don't clean up or seem busted, I'll find those replacements. Thanks guys!
Visits: 498.2K
Here's a better ideal for a drain plug.It's a marine item made by Mercury outboard. I replaced all my drain plugs, including the radiator, with them. You can even attach a hose to it. You can get it at a marine supply store, ebay. or Amazon. The last ones I bought were through ebay. Also see it under the Quicksilver brand
Posts: 1.4K,
Visits: 2.0K
Part 8115 (Concours) does show an external nipple to which a hose could be attached. I will look at mine tomorrow to see if it also has the nipple (I can't remember if it does/doesn't). Having the nipple for attaching a hose would be convenient/less mess, but not a deal breaker. I would be more concerned about the drain cock leaking, if removed/replaced.
FORD DEARBORN
Visits: 113.5K
NPD has has the wing style in brass with attached sleeve for a hose - about $7. They work great and being able to attach a hose makes for a no mess job. https://www.npdlink.com/product/drain-cock-radiator-brass-14-inch-npt/135249/51491
Tealy64
Visits: 1.3K
Now we're talking. I think I'll grab a couple and replace these. I cleaned them up yesterday and they look pretty haggard. I'm assuming a little silicone when installing the new ones?
Last Active: 8 hours ago
Tealy64
Visits: 1.3K
Those look more "period correct". How much were they?
