Problem disconnecting speedometer cable on 55 T-Bird
Posted By 312YBlock 4 Years Ago
Posted 4 Years Ago
Thanks. I don't know, yet, if my existing cable is the OEM/w clip or not, but good to know that the clip isn't needed on the replacement cable.
312YBlock
Posted 4 Years Ago
Posts: 217, Visits: 57.3K
55blacktie Today I removed the cable sheath from the transmission; my new cable is in route from Hill’s. I’ll let you know how it all goes together.
1955 312 T-Bird Warwick, NY
Posted 4 Years Ago
Thanks!
I was under my 55 a few days ago and disconnected the shifter from the transmission. I intend to remove the OEM shifter and the transmission tunnel cover plate. I will  modify/replace it to accommodate a Lokar C4 floor-mounted shifter. Maybe the cable is easier to access with the cover removed. When it comes time to install the rebuilt engine and C4 transmission, I will heed Gil Baumgartner's advice and install the cable before the transmission goes back into the car.
312YBlock
Posted 4 Years Ago
55blacktie After completely removing the cable I found out it actually is a 57 cable which was installed in my T86 OD part number 17260-B used with 1957 292 engines from Hill’s and yes it fits the 55 speedometer. All 55 to 57 cables are the same, however the transmission ends vary. I compared a new 55 S/T cable to the 17260-B and it is identical on both ends.
Posted 4 Years Ago
Thanks, 312.
I gave some thought to replacing the Fordomatic with a T5, but I haven't owned a vehicle/w a manual transmission since the 90s. Mind you, I haven't forgotten how to shift, but I've settled down and gotten lazy. Having fought commuter traffic for over 20 years might have had something to do with it as well.
312YBlock
Posted 3 Years Ago
Hi Phil, I may have stumbled upon the answer to this statement you made with regard to my difficulty removing the cable from the Speedometer in my 55.
“The connector is about an inch long and made out of a spring like material. It connects the gauge with the cable end. Why it's there, I haven't a clue”.
I believe the connector was intended to prevent the cable from being inserted too far into the Speedo housing. I lubricated and installed the new cable snugging up the fastener finger tight. On a test drive the needle vibrated only slightly and I figured that’s par for the course. After maybe 20 miles it began to make the rotational scraping sound to my great dismay, it sounded like it was coming from the speedometer itself. I unscrewed the cable and realized a bundle of wires from the dash harness was sitting on a lip of the dash applying upward pressure on the cable. I moved the harness away and reinserted the cable lightly snug. On my test drive the needle behaved perfectly without the slightest bounce or vibration, just like a modern car, I was pleasantly amazed. I believe the connector was there purposely to prevent the cable from being connected directly to the housing. My original problem began when I was unable to remove the cable after I tightening to the housing.
312YBlock
Posted 3 Years Ago
