electrolysis
Posted By darrell 4 Years Ago
Daniel Jessup
Posted 4 Years Ago
Posts: 2.0K, Visits: 131.2K
check this out - the guy who made this video loves Y blocks and uses electrolysis every once in a while...Whistling
Y Block Ford Exhaust Manifold Restoration - YouTube
Daniel Jessup
Lancaster, California
FORD DEARBORN
Posted 4 Years Ago
Posts: 836, Visits: 113.5K
Thanks Dan for the excellent video link. I may try it next summer and possibly hot-rod the process with a higher viltage source like a variac, bridge rectifier and big capacitor Just meed to be aware of the higher voltage and hydrogen/oxygen gas.  Did the ammeter on your charger indicate any current? I would guess it wouldn't be much due to the high resistnce of the liquid bath.
Daniel Jessup
Posted 4 Years Ago
I just left the charger on the 10 amp setting and let it do its work - never really got into testing the load and all of that. The charger has a 2 amp and a setting of 30 amps (to start your car if needed while charging a mostly dead battery). Electrolysis can get high tech as needed - plenty of archaeologists and treasure seekers use the process. One thing to note on gases - from what I understand this is only when dealing with certain metals - I have always read that stainless steel will give off a toxic gas. The cast iron pieces and the pot metal parts I have put into an electrolysis bath have never given off fumes. Another plus would be that the bath is completely organic and easily disposable when dealing with ferrous metals.
Daniel Jessup
FORD DEARBORN
Posted 4 Years Ago
This would be interesting to experiment with whould there be a need to do so.
2721955meteor
Posted 4 Years Ago
Posts: 927, Visits: 190.0K
I use molasses and water in a plastic barrel. best if it is kept in a warm aria. 1gallen molasses to3 water. molasses from cattle  feed store, cheap. takes about 1 to 2 months. be sure to steam clean block first so to get rid of the rust(molasses  wot clean great or oil
