Speedometer Lubricant
Posted By 312YBlock 4 Years Ago
312YBlock
Posted 4 Years Ago
Posts: 217, Visits: 57.3K
Can anyone suggest a good Speedo cable lubricate. Ideally a liquid I could let run down inside the conduit after removing it from the speedometer.
1955 312 T-Bird Warwick, NY
Posted 4 Years Ago
Last Active: 2 Weeks Ago
I’ve used this because of it’s applicator. I prefer lubriplate and removing the inner cable. I’ve never had a problem putting it back as long as it was disconnected from the transmission. I have replaced the entire cable with one from a speedo shop in Colorado after it failed. It is lined and has a plastic out cover. The wife and I put it in and we are in our last 70’s.
http://forums.y-blocksforever.com/uploads/images/c456fc37-ac85-4a46-a703-da6.jpeg
Posted 4 Years Ago
Posts: 3.7K, Visits: 498.2K
There is a lubricant name Kable-Eaze that I heard about.  Bought some and am going to try it. Got it at Amazon.
312YBlock
Posted 4 Years Ago
Does the cable just pull out once you disconnect it from the transmission?
Joe-JDC
Posted 4 Years Ago
Posts: 790, Visits: 23.2K
The spiral wire cable does pull out of the housing.  It is splined/hex/four sided ends engage the odometer.  Some devious folks used to use a reverse drill motor and back up their odometer mileage by removing the cable from the transmission.  I have always had good luck with light weight graphite grease, either dry or wet, on the cable.  Joe-JDC
312YBlock
Posted 4 Years Ago
Thanks all, good info 🍻
BKernell
Posted 4 Years Ago
Turbocharged (60 reputation)Turbocharged (60 reputation)Turbocharged (60 reputation)Turbocharged (60 reputation)Turbocharged (60 reputation)Turbocharged (60 reputation)Turbocharged (60 reputation)Turbocharged (60 reputation)Turbocharged (60 reputation)
Posts: 18, Visits: 2.3K
I have always used Vaseline and never had a problem with my speedo cable
