292 Rebuild Head Selection part 2
Posted By napaunderground 3 Years Ago
napaunderground
Posted 3 Years Ago
Supercharged (165 reputation)Supercharged (165 reputation)Supercharged (165 reputation)Supercharged (165 reputation)Supercharged (165 reputation)Supercharged (165 reputation)Supercharged (165 reputation)Supercharged (165 reputation)Supercharged (165 reputation)
Posts: 46, Visits: 111
Short version.
ECZ-G heads have to exhaust port sections that need to be pinned. (cracked) Machine shop says totally fixable, but thinks different heads would be preferrable.
I can't stomach having more heads cleaned to find out they're also bad. We're in it for $280 in cleaning already. Sad
Machine shop has a set of ECZ-C heads built and ready to go for $950
I paid $150 for the ECZ-G heads empty, so we have to buy valves, springs, etc and have the seats done and milling, etc. I assume it'll be $700 at least for head work.
What would you do? We're not trying to just spend crazy money and just want fun and reliable.
Cliff
Posted 3 Years Ago
Posts: 878, Visits: 13.5K
The C heads are fine for a driver.
napaunderground
Posted 3 Years Ago
Thanks for the response. Went with the C heads, the machinist did some port work. IDK if it was worth it. But it's done. All told for parts and machine work their part cost $5500. Now I get to play engine assembler/installer.
darrell
Posted 3 Years Ago
Posts: 455, Visits: 22.2K
ive never seen that kind of money spent on heads.
Posted 3 Years Ago
Last Active: 7 hours ago
Posts: 1.2K, Visits: 1.8K
Although it's not clear, I think it's safe to assume that's the cost for parts & machine work for the entire engine, not just the heads.
Posted 3 Years Ago
Posts: 1.9K, Visits: 194.9K
I hope so, but that’s (depending on all that was done) in the neighborhood for the Seattle area. If he’s really in NAPA, you’ve got to add the wine in for lunch, and then who knows………
idaho211
Posted 3 Years Ago
Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)
Posts: 128, Visits: 11.6K
When I had the machine work done on my 312 the cost made me think if I mess it up when I assemble it I could really waste some money so I just had him assemble it.
napaunderground
Posted 3 Years Ago
Sorry, got pulled away from all the fun by work stuff. :|
So the total cost includes
1) Replacement heads with stronger valve springs
2) Port work on the heads and 4bbl ECZ-B intake
3) Camshaft sent out and reground to a T-Bird 312 profile - true up lifters
4) Replacement crankshaft as ours was damaged due to previous mechanic not tightening flywheel bolts - machined .010 under
5) Block work - bored .040 to get true, squared
6) Cleaning 2 sets of heads that ended up being cracked... fixable, but cracked.
7) Rebuild kit with pistons, etc
8) Check/recondition rods
9) Balance rotating assy.
10) Pertronix distributor and coil
11) Timing chain, oil pump, oil pump drive
Probably something I forgot. Plus I rounded up a little.
I feel like it was a LOT, but things do cost more in this stupid place.  I also trust this machinist, so I don't mind paying a premium.
Thanks all!
napaunderground
Posted 3 Years Ago
Oh, I should mention many of the still existing and in-use vineyard fans are 292's according to the machine shop. They have rebuilt many of them.
Posted 3 Years Ago
Last Active: 4 minutes ago
Posts: 4.6K, Visits: 38.3K
http://www.ford-y-block.com/ALUMINUM%20HEADS.htm $3050
