Posts: 1.3K,
Visits: 80.0K
Haven't done this in a while, but what is the best method of holding the thermostat in place while bolting down the housing? I have a couple of ideas, but would like to know how you guys do it without having the thermostat slipping out of position. Thanks!
Ron Lane, Meridian, ID
Last Active: 4 hours ago
Posts: 1.3K,
Visits: 80.0K
Thanks Charlie! As you can see my memory is shot!
Last Active: 10 minutes ago
Visits: 497.8K
I put studs in the intake manifold. No problem in lining up the housing to the intake.
Visits: 57.3K
Use Permatex Aviation sealer on the gaskets. You can hold the thermostat in place in the housing with a rubber band. Run it through the thermostat and put the ends over a pencil, rest the pencil across the radiator hose opening in the housing. Then insert the thermostat into the manifold leaving just enough room to slip the rubber band out.
1955 312 T-Bird Warwick, NY
I have had mine off a dozen times and always had the bypass hose and the 2 bolt fitting attached to the housing and Permatex #2 both sides on its gasket. I cut the hose about 3/8” short to slide it all together. I use a 360” Mopar high flow thermostat also. Good luck.
Visits: 137.8K
3M weatherstrip cement on the thermostat edge. Glue it to the housing.
