B-rad
Visits: 1.5K
I'm sure you have read my issue, are you certain that it's what I need in order to use a non stock carb? I'm really confused about these parts. Can you post a pic and what you want for it?
RB
Last Active: 4 Months Ago
Visits: 16.7K
B-rad.. I have a Lincoln 4bbl truck manifold I would sell..
B-rad
Visits: 1.5K
Thanks Ted. You the man. I know I can get the right info from you.
Last Active: 4 days ago
Posts: 7.5K,
Visits: 205.8K
B-rad (6/27/2022) Hjh, you selling the f600 intake? Anybody know if that'll work on my 317 LYB?The 1952-1963 LYB engines take the same intake manifold gaskets so the chances are very good for the 1958-1963 4V 302/332 intake manifold fitting the earlier 317/341 engines. The Best Gasket p/n for the LYB intake manifold gasket set is “17020E”.
Posts: 7.5K,
Visits: 205.8K
B-rad (6/27/2022) The oil pump and drive needs to be a Ford or lincoln? Someone is selling a 4v intake from a 63 f600. Do you know if that'll work on my LYB?The FYB and LYB oil pumps are interchangeable. For the hex drive pump, it would 1955 and newer. The oil drive is LYB specific. The Melling number for the LYB hex intermediate shaft (oil drive) is “IS-60A”.
Visits: 1.8K
I posted a reply in Classified. Unless the F600 has a 332, it's highly unlikely; it's probably a 292, which won't fit. The 292, like the 239, 272, and 312, has stacked intake ports. The 317 has inline ports. Ask the seller to send a photo of the intake ports.
B-rad
Visits: 1.5K
hjh
Visits: 10.6K
RB
Visits: 16.7K
A 317 should be able to be bored to 341. Those blocks are quite thick.. Since the stroke is the same on the 317 and 341 no other changes should be necessary.. Change the oil pimp and distributor when you do the build. A rebuilt 57 and up FYB distributor with the Lincoln gear will work well. You can add a Pertronix if you want to eliminate points.. I prefer the truck manifold vs adapting the 317 version.. Neither one are considered high performance, But that's about the best you can do with factory stuff
Posts: 7.5K,
Visits: 205.8K
If going with a more modern carburetor, then the distributor will need to be upgraded to the 1957 and newer style that incorporates both a mechanical and vacuum feature. The original LOM (Load-O-Matic) distributors are calibrated for use with the earlier carburetors that incorporated a venturi assisted vacuum signal along with a spark advance valve. That spark advance valve is located on the outside of those earlier carbs and looks similar to the ‘power’ valve that’s located internally on the newer carbs. There was no mechanical advance feature on the LOM distributors. The earlier Teapot carbs can be modified for use with the newer distributors if so desired. Here’s the link to the article on modifying the earlier Teapot carbs for use with the later model distributors. Modifying the Holley Teapot four barrel carb for late model distributors – Eaton Balancing For a daily driver, a carb adapter on the earlier ‘Teapot’ intake manifold will allow the use of a newer ‘modern’ carb. As Darrel mentions, the later model 302 and 332 LYB truck intakes will allow the use of a modern 4V carb without an adapter. The ’54 engines used a tang style distributor to accommodate the slotted shaft oil drive and oil pump. If going with a modern distributor, the 1955 and later model ¼” hex drive oil pump and oil drive shaft will need to be used. Those pieces will interchange with the original parts without modifications. If using a Ford Y distributor, the distributor gear will need to be swapped out with the original LYB distributor gear. I currently don’t have a LYB distributor here to verify if the LYB gear is the same as the Ford FE engines but I’m told the 390 (Ford FE) gears are the same. The MSD #8383 distributor for a FYB will work on the LYB engines if changing out the distributor gear. Always measure the distributor cavity in the block so that any replacement distributor gears can be placed on the shaft in the appropriate position. I have found some FYB blocks machined on the ‘short’ side of specification and I suspect there may have been some LYB blocks machined similarly.
