Visits: 22.0K
Wrong nomenclature. It's Ford Tractor Transmission Fluid:https://www.tractorsupply.com/tsc/product/traveller-ford-tractor-hydraulic-oil-3-2-gallonAPI Service GL-1. For use in final drives, hydraulic systems, and manual transmissions of Ford Tractors manufactured between 1939 and 1952
Visits: 5.4K
THANKS!!
Visits: 112.0K
charliemccraney (7/1/2022)
Gl-5 does not indicate synthetic and most modern GL-5 is safe with yellow metals. If in doubt, refer to the manufacturer of the particular oil you want to use. What GL5 isn't synthetic? I haven't found one..
Visits: 5.4K
When I first installed this OD transmission it leaked real badly. The same was true of the rear axle pinion seal which dripped continuously. Both the transmission and the rear axle had sat uninstalled for many, many years. Gradually, the leaks slowed down and then stopped completely. Sounds crazy but the only explanation that I can think of is that the seals in the transmission and the rear end had dried up after having been drained and then left sitting for years. Once refilled with oil, the seals expanded and plugged the leaks. Anyway, I am a "happy camper" now as the OD is working and no oil leaks. Thanks to everyone who gave advise.
Visits: 112.0K
charliemccraney (7/2/2022)
Thank you. All the local big box parts stores by me only have synthetic
Visits: 5.4K
The STP 80-90 weight that I was using is GL5 but is not synthetic.
