4 blade fans improve air worth the switch
Posted By Melly 4 Years Ago
Posted 3 Years Ago
Last Active: 2 Weeks Ago
Posting removed. Information was for a car. Unknown if it pertains to a truck. Sorry.
FORD DEARBORN
Posted 3 Years Ago
Posts: 840, Visits: 113.5K
There is very good air flow through the radiator in these trucks. I have never ever had any overheating issues with my truck even on +90* days in traffic. Engine is a 312 with a mild cam. I'm presently running a 5 blade fan on a fluid clutch (Mustang) to keep it quiet at higher rpm's..Even with the stock 4 blade, there were no heating issues either. As DLR stated, an electric fan will add load to the electrical system which would be quite heavy for a generator if that's what you are running. Like, there's no free lunch. This is simply my exprience with myhttp://forums.y-blocksforever.com/uploads/images/320925dd-1ea0-4de4-9871-88ca.jpg 64 F100, your results may vary.
Tealy64
Posted 3 Years Ago
Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)Supercharged (188 reputation)
Last Active: 5 Months Ago
Posts: 54, Visits: 1.3K
Thanks FD, I'm thinking if I go with a 5 blade, maybe a little bigger (need to measure mine first) I should be good to at least to start with.  I'm here in FL where it gets mondo hot during the summer, so I want to make sure that I don't have any overheating issues.
1964 Ford F100 w/ 292 Y-block
-Central Florida-
Posted 3 Years Ago
If the temperature creeps up when idling at a stopped intersection and then does not quickly recover when moving then the smaller water pump pulley with definitely help. These vehicles did not heat up when new or for many years after being built and the only real difference is the formulation of the gasoline which we do not control. Good luck
FORD DEARBORN
Posted 3 Years Ago
Some of these trucks (71-74) were built with fan shrouds depending on engine option. A shroud would be a big plus if your truck doesn't have one. There usedto be a fella who specializes in vintage Ford trucks and salvaged parts. I'll try to find that source and report back just in case you might want to explore that option.
FORD DEARBORN
Posted 3 Years Ago
Found it and will attempt to post the link - called Flashback F100's.  Has been a very good source of vintage Ford truck parts,  great folks to do business with when restoring my truck many years ago and interesting web site to explore.  Hope this helps.......      http://flashbackf100s.com/about_us
