WANTED: STOCK REAR AXLE U-BOLTS AND BOTTOM SHOCK MOUNTING PLATES
Posted By alanfreeman 3 Years Ago
alanfreeman
Posted 3 Years Ago
Supercharged (892 reputation)Supercharged (892 reputation)Supercharged (892 reputation)Supercharged (892 reputation)Supercharged (892 reputation)Supercharged (892 reputation)Supercharged (892 reputation)Supercharged (892 reputation)Supercharged (892 reputation)
Last Active: 16 hours ago
Posts: 363, Visits: 5.2K
Does anyone have a set of four good original stock rear end u-bolts and a pair of bottom shock mounting plates? I just discovered that the 9" Ford rear end that I removed from my '54 Ford used different size parts than the original rear end that I am putting in my car. Thanks, Alan
Posted 3 Years Ago
Last Active: 6 hours ago
Posts: 1.2K, Visits: 1.8K
Why do you want to use used u-bolts?
alanfreeman
Posted 3 Years Ago
I need U-Bolts to hold the leaf springs to the rear axle.  Isn't that the way Henry built these cars at the factory????  Alan
Posted 3 Years Ago
Last Active: 7 hours ago
Posts: 3.6K, Visits: 497.6K
He's asking why you want  used parts, rather than new.  New u bolts might be available locally.
alanfreeman (4/26/2022)
alanfreeman
Posted 3 Years Ago
The closest size new U-Bolts that I was able to find were 3" across which would fit loosely on the axle housing.  If someone knows a source for the correct size that will correctly fit a stock rear end please let me know.
Lou
Posted 3 Years Ago
Posts: 559, Visits: 8.3K
A "spring" shop can make u-bolts for you.
alanfreeman
Posted 3 Years Ago
I checked one of my other '54 Fords and discovered that the original stock u-bolts are actually 3" inside diameter although the outside diameter of the stock axle is  a little less than that.  As the u-bolts and shock mounts that were used with the 9" Ford axle that was in my car are 3" I will use them to secure the stock axle.  Thanks for your responses.  Alan
