WANTED: STOCK REAR AXLE U-BOLTS AND BOTTOM SHOCK MOUNTING PLATES
http://forums.y-blocksforever.com/Topic160862.aspx
By alanfreeman - 3 Years Ago
Does anyone have a set of four good original stock rear end u-bolts and a pair of bottom shock mounting plates? I just discovered that the 9" Ford rear end that I removed from my '54 Ford used different size parts than the original rear end that I am putting in my car. Thanks, Alan
By 55blacktie - 3 Years Ago
Why do you want to use used u-bolts?
I need U-Bolts to hold the leaf springs to the rear axle.  Isn't that the way Henry built these cars at the factory????  Alan
By paul2748 - 3 Years Ago
He's asking why you want  used parts, rather than new.  New u bolts might be available locally.
alanfreeman (4/26/2022)
The closest size new U-Bolts that I was able to find were 3" across which would fit loosely on the axle housing.  If someone knows a source for the correct size that will correctly fit a stock rear end please let me know.
By Lou - 3 Years Ago
A "spring" shop can make u-bolts for you.
I checked one of my other '54 Fords and discovered that the original stock u-bolts are actually 3" inside diameter although the outside diameter of the stock axle is  a little less than that.  As the u-bolts and shock mounts that were used with the 9" Ford axle that was in my car are 3" I will use them to secure the stock axle.  Thanks for your responses.  Alan
