1955 Ford Car Trunk Lid Springs Part Numbers
Posted By bergmanj 3 Years Ago
bergmanj
Posted 3 Years Ago
Posts: 257, Visits: 3.9K
Folks,
Looking for trunk lid springs part numbers [1955 Ford car]; have the part numbers & illustrations books, but can't find the springs - probably overlooking them! Anyone?
Thanks, JLB
Posted 3 Years Ago
Is this what you are looking for?
http://forums.y-blocksforever.com/uploads/images/86532539-083e-4c3f-8fde-dd45.jpg
http://forums.y-blocksforever.com/uploads/images/341c5a59-2e13-4f40-a698-33c2.jpg
bergmanj
Posted 3 Years Ago
Ted,
YES!!  Just Couldn't find that; it will help a great deal.
My '55 Crown trunk lid won't stay completely up; was looking at T'Bird "heavy duty" springs as a replacement; but, don't know if they're the same. This is where comparing part numbers is really useful for substitutions that will actually work.
Thank you
bergmanj
Posted 3 Years Ago
Folks, FYI:
The '55 & '56 "SPRING, LUGGAGE COMPARTMENT DOOR HINGE", Ford P/N B7S-4042760-A (Ford parts book section 42760) is the same for both the 55/56 Sedan cars & the '57 T-Bird.
NPD T-Bird part number T-0420701-2 claims to be a "heavy duty" version which will "cure" the trunk-lid "drooping" as mine does. This issue was apparently fairly typical for both '55 & '56 cars.
Hope this helps others with the same issue.
Regards, JLB
Posted 3 Years Ago
Posts: 1.2K, Visits: 1.8K
How much force is required to close the trunk/w "heavy duty" spring?
54RedTruck
Posted 3 Years Ago
Hitting on all eight cylinders (11 reputation)Hitting on all eight cylinders (11 reputation)Hitting on all eight cylinders (11 reputation)Hitting on all eight cylinders (11 reputation)Hitting on all eight cylinders (11 reputation)Hitting on all eight cylinders (11 reputation)Hitting on all eight cylinders (11 reputation)Hitting on all eight cylinders (11 reputation)Hitting on all eight cylinders (11 reputation)
Posts: 4, Visits: 12
I have severe "sag" on my '57 trunk lid.
Just ordered a pair of CASCO's part number  42701B springs which they advertise as "Stonger than 42701A" which are the '55-56 spec springs.  Will report back after I install them.
Jeff
Jeff Davis
'54 F-100 - 272 Y Block
'57 Tunderbird Colonial White 312 Y Block
'57 Triumph 6T 650cc - my other Thunderbird
'56 F-350 FORD factory Script  Stakebed Dually - 292 Y Block
Wellington, Florida
Posted 3 Years Ago
The 57 trunk is larger & heavier, which explains why it needs a stronger spring. My 55 springs, which could be the originals, are adequate.
