1955 Ford Car Trunk Lid Springs Part Numbers
http://forums.y-blocksforever.com/Topic160846.aspx
By bergmanj - 3 Years Ago
Folks,
Looking for trunk lid springs part numbers [1955 Ford car]; have the part numbers & illustrations books, but can't find the springs - probably overlooking them! Anyone?
Thanks, JLB
By Ted - 3 Years Ago
Is this what you are looking for?
http://forums.y-blocksforever.com/uploads/images/86532539-083e-4c3f-8fde-dd45.jpg
http://forums.y-blocksforever.com/uploads/images/341c5a59-2e13-4f40-a698-33c2.jpg
Ted,
YES!!  Just Couldn't find that; it will help a great deal.
My '55 Crown trunk lid won't stay completely up; was looking at T'Bird "heavy duty" springs as a replacement; but, don't know if they're the same. This is where comparing part numbers is really useful for substitutions that will actually work.
Thank you
Folks, FYI:
The '55 & '56 "SPRING, LUGGAGE COMPARTMENT DOOR HINGE", Ford P/N B7S-4042760-A (Ford parts book section 42760) is the same for both the 55/56 Sedan cars & the '57 T-Bird.
NPD T-Bird part number T-0420701-2 claims to be a "heavy duty" version which will "cure" the trunk-lid "drooping" as mine does. This issue was apparently fairly typical for both '55 & '56 cars.
Hope this helps others with the same issue.
Regards, JLB
By 55blacktie - 3 Years Ago
How much force is required to close the trunk/w "heavy duty" spring?
By 54RedTruck - 3 Years Ago
I have severe "sag" on my '57 trunk lid.
Just ordered a pair of CASCO's part number  42701B springs which they advertise as "Stonger than 42701A" which are the '55-56 spec springs.  Will report back after I install them.
Jeff
The 57 trunk is larger & heavier, which explains why it needs a stronger spring. My 55 springs, which could be the originals, are adequate.
