SPIN ON OIL FILTER ADAPTER REMOVAL
Posted By alanfreeman 3 Years Ago
alanfreeman
Posted 3 Years Ago
Supercharged (911 reputation)Supercharged (911 reputation)Supercharged (911 reputation)Supercharged (911 reputation)Supercharged (911 reputation)Supercharged (911 reputation)Supercharged (911 reputation)Supercharged (911 reputation)Supercharged (911 reputation)
Posts: 368, Visits: 5.4K
The 292 engine in the car that I recently bought had been converted to have a modern type spin on oil filter rather than the original canister & can type.  I am restoring the car back to the original canister type filter.  I removed that hollow threaded center adapter bolt/nut and I thought that the round adapter plate would be released from the engine block but the plate is stuck to the block and won't come out.  Is there something else holding the adapter plate other than the center bolt/nut?  I am trying to remove the plate without destroying it as I wanted to use it on another engine that I have. Thanks
one piece at a time
Posted 3 Years Ago
Supercharged (120 reputation)Supercharged (120 reputation)Supercharged (120 reputation)Supercharged (120 reputation)Supercharged (120 reputation)Supercharged (120 reputation)Supercharged (120 reputation)Supercharged (120 reputation)Supercharged (120 reputation)
Last Active: 7 Months Ago
Posts: 50, Visits: 21.9K
No. It’s just stuck. Work at it with a 90* pick through the oil hole until lit releases. Do you need a canister?
Duane
alanfreeman
Posted 3 Years Ago
Got it with a long screw driver and a hammer and the thick gauge metal wasn't even damaged.  Someone had Permatexed the adapter to the engine block and this is why it was stuck.  Thanks
Posted 3 Years Ago
Posts: 3.7K, Visits: 497.8K
If you need a canister, I have an extra one
alanfreeman
Posted 3 Years Ago
Thanks, but I have an extra canister.  Alan
