Last Active: 8 days ago
Visits: 32.6K
Having trouble getting my Fordomatic Pan to stop dripping. I have a new Gasket to install and try again.. Any Tips on getting a dry drip free Installation? Thanks
Visits: 13.5K
Check the linkage seal, it will run down the side to the pan.
Visits: 32.6K
Done that. It is the Pan Gasket itself leaking.
Visits: 13.5K
I have the best luck with a dry pan with no sealer, do not over tighten the bolts, make sure the pan is straight.
Visits: 32.6K
Sealers are not recommended when using a Gasket. should be put on dry as You mentioned. The Specs call for 10 FT/Pounds of Torque on the Bolts.
Visits: 323.2K
Often the bolts have been previously over tightened and distorted the pan flange. I always put the pan edge on an anvil and tap each bolt hole location with a hammer to level the flange.
I thought the pan was my leak, then the fill tube, but found it was the breather about 3/4 up the side just as the case transitions to the bell. On a different trans I found SBC tin rocker arm cover spreaders put even pressure on the gasket and stopped a weeping leak. . Good luck
