Visits: 5.1K
Hi All,
So I have my engine back and the oil pump is on. She will be on a stand for quite awhile so I was hoping to circulate some oil through the passages just to keep things lubed up right before I stuff her. What do you use to turn the oil pump-besides a drill on reverse.
Mike
Last Active: 7 Months Ago
Visits: 21.9K
Use an impact drive extension long enough to reach the oil pump drive. 1/4” I use an old oil pump drive with a 1/4” socket welded to it so the socket won’t come off. DO NOT use socket and extension as thy tend to separate and fall into the oil pan. I could tell how I know.
Duane
A speed wrench, if a drill is not an option.
Visits: 112.0K
I bought a priming tool years ago, and use it with a 3/8 drill. No chance of loosing a socket and it works on all engines with 1/4 hex drive..
Posts: 7.5K,
Visits: 205.8K
Visits: 5.1K
Thanks.
Visits: 497.8K
I use a speed wrench handle with a 1/4 inch drive 1/4 deep socket, possibly a short extension. All taped together to make sure it does not come apart. Counterclockwise. Usually only takes a minute or two to get oil up top.
