Strange Installation Problem - Engine too far forward
Posted By Jack Groat 4 Years Ago
blocky
Posted 4 Years Ago
Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)Supercharged (311 reputation)
Posts: 127, Visits: 2.9K
hi you have probably checked this already,, but have you done ANYTHING to the rear gearbox mount crossmember?? i assume the selectors do not mate up??just a thought good luck.
Carefree Charlie
Posted 4 Years Ago
Supercharged (87 reputation)Supercharged (87 reputation)Supercharged (87 reputation)Supercharged (87 reputation)Supercharged (87 reputation)Supercharged (87 reputation)Supercharged (87 reputation)Supercharged (87 reputation)Supercharged (87 reputation)
Last Active: 2 Weeks Ago
Posts: 31, Visits: 22.8K
Exactly the same transmission? If it is a standard transmission, does the clutch "horseshoe" line up with the ball joint on the engine and the fulcrum on the frame? If so it would appear the engine is set properly.
Posted 4 Years Ago
You didn't respond to Deyomatic's question?.. This may be silly question?  Are you sure the Bell housing & trans are together properly?  If not, is it possible that your replacement engine was from an automatic car & your car is a standard. I believe that requires machining the end of the crank for a suitable pilot bushing setup ..
darrell
Posted 4 Years Ago
Posts: 455, Visits: 22.2K
cranks are all the same
Posted 4 Years Ago
I’m going to suggest looking at the transmission mount more closely.  If it’s the old mount, then try flipping it around 180° as it may have an offset in the mounting holes.  If the transmission mount is new, then compare it to the old one if you still have it.
Jack Groat
Posted 4 Years Ago
Posts: 142, Visits: 1.4K
Thanks for all the replies and suggestion.  To answer your questions...
The transmission is a 5 speed Mustang, but it was on the old engine too.
Where the shift stub comes through the hole in the floor appears to be 1" forward also.
I am using the old bell housing.
The engine/transmission/bell housing are fully mated and torqued to spec.
The clutch linkage looks like the engine is forward in location. (not properly aligned)
darrell
Posted 4 Years Ago
if the mounts are the same then the motor is in the same place it was before.it cant be in a different place.the only way is the mounts are different.its impossiable to be forward 1 inch.the only way that could happen is the old mounts are 6 cyl
Posted 4 Years Ago
Posts: 3.7K, Visits: 323.0K
In your assortment of parts do you have a flat plate that you don't recognize?  When we put a late 5 speed in my son's early Mustang, we had to make an adapter plate for above the transmission mount so that the mount would bolt up with the engine sitting on the original front mounts.  If I remember correctly, it was a piece of 1/4" steel plate wide enough to accommodate the bolt holes in the transmission and long enough to bolt to the mount to match the holes in the mount.  A flat plate with 4 holes in it.
Posted 4 Years Ago
Posts: 3.6K, Visits: 497.7K
It all boils down to the engine mounts from what you have said (everything is forward from the z bar mounts to the rear emgine mount and the hole for the shifter)- so the mounts cannot be the same.  Check further on this.  Either the mounts are backwards, are the wrong mounts or badly manufactured. .  Do a closer examination of them - they may look the same but are they really the same?. Measuring them may tell the tale.
Do you still have the old mounts?
Jack Groat
Posted 4 Years Ago
PROBLEM SOLVED!!!  It was the motor mounts.  Getting one of the new ones out and comparing it to the old one, there is a 3/4" shift in the attaching studs/bolt holes.  Very unhappy with the people who supplied the reproduction.
Thanks guys....
