292 vibration 57 f100
Posted By Dooley 4 Years Ago
Dooley
Posted 4 Years Ago
Hitting on all eight cylinders (21 reputation)Hitting on all eight cylinders (21 reputation)Hitting on all eight cylinders (21 reputation)Hitting on all eight cylinders (21 reputation)Hitting on all eight cylinders (21 reputation)Hitting on all eight cylinders (21 reputation)Hitting on all eight cylinders (21 reputation)Hitting on all eight cylinders (21 reputation)Hitting on all eight cylinders (21 reputation)
Posts: 7, Visits: 2.6K
Hi all, I’ve been trying to sort out a bad vibration it’s bad enough to make her un-drivable. Vibration starts through out rev range, stationary, clutch in or out. Things I’ve already done: machined & balanced flywheel, clutch & pressure plate, engine mounts, rebuilt Damper, spark plugs etc, cab bolts & engine mount bolts all tight. Vibration doesn’t seem bad under the hood but really noticeable in cabin, steering wheel vibration is real bad & cab shakes & rattles. It’s getting real frustrating as even local mechanics are scratching their heads. Cheers
Posted 4 Years Ago
Last Active: 5 days ago
You don't mention how long or when this problem started which could help in determining the cause.  How about disconnecting the belts and cranking up the engine to eliminate a vibration originating from one of the engine accessories?  Another option is performing a compression test on the engine which would help to rule out a weak or dead cylinder.
Dooley
Posted 4 Years Ago
I purchased it with the issue thinking I was an easy fix. I’ve removed the belt and no change, number 2 piston is down lower compared to the rest but not way down.
Deyomatic
Posted 4 Years Ago
Supercharged (851 reputation)Supercharged (851 reputation)Supercharged (851 reputation)Supercharged (851 reputation)Supercharged (851 reputation)Supercharged (851 reputation)Supercharged (851 reputation)Supercharged (851 reputation)Supercharged (851 reputation)
Posts: 292, Visits: 2.3K
Does it happen when it's moving?  I had an unknown vibration in my old 55 Fairlane where the driveshaft was slightly out of balance and first took out my driveshaft yoke/ tailshaft seal- so I replaced the seal.  Within a couple of months the vibration was unmanageable.  Turned out that unbalanced driveshaft took out my tailshaft!  Ended up getting a used tranny and having a hot rodder buddy make it fit.
Dooley
Posted 4 Years Ago
Vibration the same when stationary.
Posted 4 Years Ago
Posts: 1.2K, Visits: 1.8K
Internal balance? Did the seller provide any history? How long had he owned it? When did the vibration begin?
Posted 4 Years Ago
Does it get better/worse with change in rpm?
Dooley
Posted 4 Years Ago
Seller won’t return phone calls unfortunately. Gets worse with higher rpm, a friend said it might be main bearings? I’ve had it just under a year and been trying to sort it out ever since. I’m convinced it’s internal balance issue as I’ve tried everything else I can think of.
Posted 4 Years Ago
If the engine was rebuilt or throwed together with a hodgepodge of parts, then an imbalance due to a mismatch of parts would be high on the list.  If the oil pressure is good, then worn main bearings is low on the list.  Check the head casting numbers on the heads to verify that both heads are the same.  At this point, there’s also the probability that one head is milled much more than the other.  While this has likely already been performed, check the spark plug wires for having the correct firing order.  You don’t mention valve lash but that should also be double checked.
I’ll still suggest performing a compression test as that may give a better idea of where to look when the engine is torn down for examination.  While the spark plugs are out for the compression test, examine them closely for any irregularities in the color or burn patterns.
panel driver
Posted 4 Years Ago
Posts: 119, Visits: 6.0K
You mentioned that number 2 piston is down lower than the others. Maybe mismatched connecting rod length,
or bent connecting rod.   Try checking running compression.   Just a stab in the dark.
