Electronically Controlled Voltage Regulator?
Posted By Half-dude 4 Years Ago
Half-dude
Posted 4 Years Ago
Supercharged (587 reputation)Supercharged (587 reputation)Supercharged (587 reputation)Supercharged (587 reputation)Supercharged (587 reputation)Supercharged (587 reputation)Supercharged (587 reputation)Supercharged (587 reputation)Supercharged (587 reputation)
Posts: 224, Visits: 11.3K
A lot of times when I take my 55' out driving I'll hear noise from the voltage regulator, it's actually a bit disconcerting because it's easy to miss that that's what it is especially on a nice summer day as it sounds like someone running a weed-eater off in the distance. Then you keep driving a few more blocks and then keep hearing it and you're like "wait." It seems like it usually stops eventually but it concerns me what it could be doing to the electrical system if perhaps those points are rusting together between trips or arcing.
I know I'm definitely preaching to the wrong crowd here. But I'm more likely to feel more comfortable if I could use a computer-controlled electronically modulated voltage regulator. Does anyone know if there exists any modern replacements to use on classic cars? Perhaps ones that look like the old original on the outside while modern internally?
Tedster
Posted 4 Years Ago
Posts: 513, Visits: 153.3K
Bosch still makes a 12 volt solid state VR for their generator equipped VWs, #30019 this is assuming your 55 has been converted to 12 volts. It won't look period correct. Nobody currently (heh) makes a solid state reproduction. NAPA still offers U.S.A. made adjustable generator VRs
If there is a defect in your generator, it is unlikely a solid state unit would be very happy with that either. It would like fail very quickly.
I'm going through a generator now, polishing commutator, undercutting mica, new brushes etc. It's easy to see why alternators became popular. What started out as a "quick" inspection of the brushes (somehow) turned into a full generator R&R rebuild. Better now when the weather is nice.
