292 Street Build
Posted By Eric16 5 Years Ago
Cliff
Posted 5 Years Ago
Posts: 908, Visits: 14.0K
Why not just build a 312? it's a lot cheaper, that's what I run in both of my street cars, my supercharged bird was built in 1994 with no problems.
Posted 5 Years Ago
The glove box door droops a bit, just like on my 55 Tbird. I think most of them are like that. As long as it doesn't rattle, I'm good with it.
Posted 5 Years Ago
I remember having seen your a/c unit before and commenting that it's the nicest installation I've seen. I would say that applies to the whole car as well.
Posted 5 Years Ago
DLR, I have the Newport wipers, as well, but haven't installed them. I'm also converting to manual heater control valve; getting rid of the vacuum stuff.
Posted 5 Years Ago
And thanks, DLR, for not making noise, just for the sake of making noise.
Posted 5 Years Ago
By the way, I would like to hear more about your Sirius conversion. I plan to do the Aurora conversion, but maybe there's a better option.I stopped listening to over-commercialized am radio in 1967. Unfortunately, fm is now the new am. No more "free lunch."
Posted 5 Years Ago
Take a look at Mummert's Y-280-1-11 cam specs at ford-y-block-com. You have the gears, and the 111 LSA should be ok with the Sniper. You might also look at Isky's RPM 300 cam, but Ted says that Y-blocks like lift; in which case, the Y-280-1-11 would be the better choice. I would also zero-deck the block and mill the heads if using flat-top pistons, preferably with metric rings. If I could afford $3,000+ for Mummert's  aluminum heads, I would either go that route or consider forced induction. Your budget might be the deciding factor.
Posted 5 Years Ago
Eric16, you can find Y-block intake, carburetor, and header tests, along with numerous Y-block engine builds, at eatonbalancing.com. Click on "Quick Index."
Eric16
Posted 5 Years Ago
Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)Hitting on all eight cylinders (10 reputation)
Posts: 5, Visits: 113
What are you running for a motor, trans, and rear end to get such a good combo in your Victoria?
1956 Ford Victoria
1932 Ford Roadster
Eric16
Posted 5 Years Ago
I didn't have an exact number I was set on. Just digging through some of Ted's builds, 300hp didn't seem too unrealistic. My goal was to stick with the iron heads and intake, and have a shop massage them a little bit, and see what I can get.
1956 Ford Victoria
1932 Ford Roadster
