Ported vacuum vs venturi vacuum
Posted By Tedlauri 4 Years Ago
Tedlauri
Question Posted 4 Years Ago
Supercharged (102 reputation)Supercharged (102 reputation)Supercharged (102 reputation)Supercharged (102 reputation)Supercharged (102 reputation)Supercharged (102 reputation)Supercharged (102 reputation)Supercharged (102 reputation)Supercharged (102 reputation)
Posts: 40, Visits: 11.3K
I always assumed ported vacuum was venturi vacuum, but now I have heard they are different. I do know what manifold vacuum is. I have a 1956 f100 272 with a 1957 distributor and the vacuum advance is hooked to the port at the back of the 2 barrel carb above the throttle so the vacuum advance gets no vacuum at idle but does get vacuum as I open the throttle. Do I have it hooked up correctly?http://forums.y-blocksforever.com/uploads/images/35e3842c-40bd-445d-86fb-fcf.jpeghttp://forums.y-blocksforever.com/uploads/images/ff98e4bb-607b-4290-8e85-319.jpeg
1956 F100 272 4 speed
Northern California
Threaded View
Threaded View
Forum Post Ported vacuum vs venturi vacuum By Tedlauri ( 4 Years Ago )
Forum Post The ’56 and earlier carbs incorporate both venturi and ported vacuum... By Ted ( 4 Years Ago )
Forum Post ok thank you, can you tell from my picture what the year and model of... By Tedlauri ( 4 Years Ago )
Forum Post From the 1 and 1/16 bore size, to the butterfly linkage, to the air... By Daniel Jessup ( 4 Years Ago )
Forum Post No numbers that I can see By Tedlauri ( 4 Years Ago )
Forum Post I drove around with a vacuum gauge hooked up to the threaded port up... By Tedlauri ( 4 Years Ago )
Forum Post [quote]I drove around with a vacuum gauge hooked up to the threaded... By KULTULZ ( 4 Years Ago )
Forum Post Yes the distributor does have weights and springs so at least 1957 and... By Tedlauri ( 4 Years Ago )
Forum Post 15" or better at cruise is pretty typical I expect. The more, the... By Tedster ( 4 Years Ago )
Forum Post Let me throw this into the conversation. Are you sure you... By Ted ( 4 Years Ago )
Forum Post Sorry I now see my carburetor pictures showed the old 1956 distributor... By Tedlauri ( 4 Years Ago )
Forum Post I will try to make a video of the vacuum gauge responding to the gas... By Tedlauri ( 4 Years Ago )
Forum Post You have the 1957/59 DUAL ADVANCE DIST w the SINGLE BREAKER PLATE (it... By KULTULZ ( 4 Years Ago )
Forum Post [quote]Yes the distributor does have weights and springs so at least... By KULTULZ ( 4 Years Ago )
Forum Post Actually it drives really nice, no pinging, quick throttle response... By Tedlauri ( 4 Years Ago )
Forum Post [YouTube]http://www.youtube.com/watch?v=a_2qecqqHho[/YouTube] By Tedlauri ( 4 Years Ago )
Forum Post You've got it brother! No shake, rattle or roll, no tip-in hesitation... By KULTULZ ( 4 Years Ago )
Forum Post Thanks, I was wondering if the carb could have been modified, from... By Tedlauri ( 4 Years Ago )
Forum Post You do have ported vacuum signal now. Venturi vacuum was one source of... By KULTULZ ( 4 Years Ago )
Forum Post It sounds like you're actively trying to find something to worry... By Tedster ( 4 Years Ago )
Forum Post Thanks for that, all you guys are full of really good information,... By Tedlauri ( 4 Years Ago )
