Ported vacuum vs venturi vacuum
http://forums.y-blocksforever.com/Topic157589.aspx
By Tedlauri - 4 Years Ago
I always assumed ported vacuum was venturi vacuum, but now I have heard they are different. I do know what manifold vacuum is. I have a 1956 f100 272 with a 1957 distributor and the vacuum advance is hooked to the port at the back of the 2 barrel carb above the throttle so the vacuum advance gets no vacuum at idle but does get vacuum as I open the throttle. Do I have it hooked up correctly?http://forums.y-blocksforever.com/uploads/images/35e3842c-40bd-445d-86fb-fcf.jpeghttp://forums.y-blocksforever.com/uploads/images/ff98e4bb-607b-4290-8e85-319.jpeg
By Ted - 4 Years Ago
The ’56 and earlier carbs incorporate both venturi and ported vacuum attributes at that port you are using.  The spark control valve below that port helps to differentiate between the two when using a Load-O-Matic distributor.  When going with the ’57 and newer distributors, it is recommended to run ported vacuum only to the distributor.  Here’s the link to the article that was published in The Y-Block Magazine that goes into detail on how to convert your particular carburetor so it’s compatible with the ’57 and newer distributors.
https://www.eatonbalancing.com/2010/02/07/modifying-the-holley-94-two-barrel-for-late-model-distributors/
ok thank you, can you tell from my picture what the year and model of this carburetor is?
By Daniel Jessup - 4 Years Ago
From the 1 and 1/16 bore size, to the butterfly linkage, to the air horn, it looks to me like you have a 1955/56 F100 carburetor that were common to the 239's and 272's. Your air horn is specifically for a truck air cleaner. I "think" that all light trucks with the 2 barrel carb in both 55 and 56 would have had a manual choke carb (which the ECG 5 certainly is). The ECG 6 would be the automatic choke 2 barrel that was a one year only on passenger cars. The carburetor looks to be an ECG 5... if memory serves, the absence of a ball style linkage would point to a post flathead carburetor and we all know that the last year for flatheads was 1953. Not sure if your carb would be a 54 model... that could be. What letters/numbers are not the drivers side of the fuel bowl? Maybe some other guys will chime in here and correct me. Cool
No numbers that I can seehttp://forums.y-blocksforever.com/uploads/images/14de741a-4205-4dda-bacc-c9e.jpeg
I drove around with a vacuum gauge hooked up to the threaded port up high on the back of the carburetor which I believed to be venturi vacuum but it acted like how I understand ported vacuum should work.  At idle it was down to zero, cruising at around 2000 rpm it was about 15 on the gauge and when I hit the gas it drops.  The more I step on it the more it drops
By KULTULZ - 4 Years Ago
Possibly the CARB modification has already been performed if getting true ported vacuum signal and the engine has a 57/ DIST?
And then again, maybe not -
When using these carbs with the later model distributor which incorporates both a centrifugal and vacuum advance system, hooking up the vacuum advance without any carb modifications will provide an excess of vacuum signal to the distributor’s vacuum advance chamber at both idle and full throttle.  This in turn creates tuning and drivabilty issues as well as increasing the propensity for detonation.  Here is a pictorial in which to convert the Holley 94’s and 2100’s so that only a ported vacuum signal is supplied to the distributor and in turn makes this older model carburetor function similar to the ’57 and up carbs in both performance and fuel economy.
Yes the distributor does have weights and springs so at least 1957 and there is no vacuum at idle and almost no vacuum at full throttle. Cruising at 2000 rpm the gauge says between 15 and 20 inches of vacuum
By Tedster - 4 Years Ago
15" or better at cruise is pretty typical I expect. The more, the better for street driven engines basically. Can learn a lot from watching a vacuum gauge driving around under various conditions. We always read about how the engine vacuum goes away when accelerating. Well, it comes right back too, and in just a split second! All I can say, is that distributor advance plate must get a real workout, and earns its keep.
What kind of vacuum advance mechanism does your distributor have? Early to mid Ford distributors and service replacements used a spring, fiber block of specific length, and metal shims (washers) to calibrate the total vacuum advance (and how fast) inside the canister. Later vacuum advance canisters are more simply adjustable with an allen wrench. The early style with the hard line are a bit of a pain to work around, but I like them.
My Y-Block runs about 52° so BTDC "all in" running down the highway near as I can figure. It will give a false indication of a bit more than that on the balancer when measured in neutral, because there is no load whatsoever on the engine under that condition.
Your vacuum reading (ported) is correct. When you open the throttle blades the manifold vacuum drops.
Are you having some sort of performance problem?
Let me throw this into the conversation.
Are you sure you have a ’57 up distributor?  The picture you provided is not clear on this but it does look like the larger vacuum advance chamber which would be a LOM (Load-O-Matic) distributor.  The LOM distributors are identifiable by their ‘straight’ points with the advance springs within the distributor being on top of the breaker points plate.  The ’57 and up distributors use the ‘curved’ points while the springs and weights are under the breaker point plate and cannot be easily seen.
Does the vacuum signal drop to zero when driving and going to full open on the throttle?  If not, then there is a given amount of venturi vacuum signal taking place.  15”-20” Hg vacuum is on the high side for what would be considered strictly a ported vacuum signal but sounds right for both a venturi and ported signal working in tandem with each other.  While that 15” Hg works well with a LOM distributor, it’s on the high side for a distributor that incorporates both mechanical and vacuum advance capabilities.
Both the venturi and ported (part throttle) vacuum signals are present in that particular distributor if unmodified.  Both vacuum types will be present at different rpm and load conditions at that single port that you are taking the vacuum signal from.  At idle and with an engine in good condition, there is not expected to be either a venturi or ported vacuum signal present and that’s by design.  Only once the throttle is opened slightly to expose the ported vacuum port located just above the throttle blades at idle will vacuum start to be generated for distributor use.  AS the engine speed picks up, the venturi vacuum is added to the mix.  I trust some or all of that made sense.
Sorry I now see my carburetor pictures showed the old 1956 distributor , these are current pictures of what I was told is a 1957 distributor http://forums.y-blocksforever.com/uploads/images/2c369d26-abf7-4200-bdbc-c88e.jpghttp://forums.y-blocksforever.com/uploads/images/3616888a-14cf-4f09-b291-574b.jpghttp://forums.y-blocksforever.com/uploads/images/6cef240a-60fc-41d9-959c-139c.jpg
Actually it drives really nice, no pinging, quick throttle response and smooth idle
I will try to make a video of the vacuum gauge responding to the gas pedal while driving. The gauge is at zero at idle and almost down to zero at full throttle.
Also thanks for all the input
You have the 1957/59 DUAL ADVANCE DIST w the SINGLE BREAKER PLATE (it advances/rotates while riding on ball bearings). The vacuum advance canister is correct also. You should be good to go.
You've got it brother!
No shake, rattle or roll, no tip-in hesitation and she sounds perfect to me.
Someone had to modify the carb at some point for the 57/ DUAL ADV DIST.
Thanks,  I was wondering if the carb could have been modified, from what I understand it acts more like ported vacuum and not venturi vacuum
You do have ported vacuum signal now. Venturi vacuum was one source of vacuum signal used on the older/previous LOAD-O-MATIC SYSTEM.
You are OK (IMO).
It sounds like you're actively trying to find something to worry about, ha ha. This should not be difficult these days. I'm prone to this at times. Proper setup of the vacuum advance is critical, I think, for an all around good smooth and cool running "street" engine. Detroit thought so too, they incorporated it practically from the beginning. But you might need to back up a bit.
It's important to tune the ignition timing in sequence or correct order. The way to do that, is disconnect and plug the vacuum advance. Forget, for the moment, that it even exists. (Remember hot rodders and drag racers don't even have a vacuum advance on their motors, because it isn't doing anything under full throttle).
Using your timing light, first ensure that the mechanical or centrifugal advance is doing what it's supposed to do, and, just as importantly, when it's supposed to be doing it, from idle to wide open throttle, and everything in between. Cruise level RPM.
In a stock Y Block wide open throttle might be something like 34 to 36 degrees (maybe more) of ignition advance, and importantly all before 3000 RPM. This can be achieved by adjusting the internal distributor combination of slots and springs. This might take a few test drives with vacuum advance disabled.
In effect what you're doing is using your engine as a distributor test machine. Most Y Blocks seem to like plenty of initial advance, more than the factory spec of 3 to 6 degrees. Somewhere around 12 degrees or so. This setting however might require some adjustment internally to limit or prevent excessive "total" advance.
Anyway once you optomize or "curve" your mechanical ignition advance, then you can re-connect the vacuum canister and play with that. The shop manual lists all the specifications in the Ignition section, what it should be at various RPM or vacuum levels - but keep in mind those published numbers are based on distributor degrees, not crankshaft degrees. They will be exactly double at the crankshaft. This is good place to start.
Yes it's true, doing all of this stuff can be tedious without a distributor machine, but it's worth taking the time if you want a good, sharp tune.
Thanks for that, all you guys are full of really good information,  You're right there is plenty to worry about these days that's probably why I don't mind directing my thoughts towards something I can somewhat control.  I wish this website was out there 50 years ago when I was messing with cars as a teenager. This old truck runs fine, I started this post to see what this carburetor had for vacuum and I sure learned a lot even though I'm still not sure if I have ported or venturi vacuum. That's why I put the video on here so someone could tell me.
