Shocks: see "Stuff that Fits"
Posted By bergmanj 4 Years Ago
bergmanj
Posted 4 Years Ago
Posts: 257, Visits: 3.9K
Folks,
I have a question posted in "stuff that fits" regarding shocks: Please look and answer if you have information.
Regards, JLB
bergmanj
Posted 4 Years Ago
A few replies: Thanks!
I still need the extended length OEM length spec's.  This affects ability to change tires/wheels when on car - without enough "drop" folks sometimes need to let air out of tires to get them off/on. I'm trying to avoid that situation - don't want to buy the "wrong" shocks.
Thaks again, JLB
Posted 4 Years Ago
Posts: 4.6K, Visits: 38.3K
I don't remember the specs but there are a set of front shocks for a Ford F150 that work. They operate in the same range but drop a couple inches further when jacked up. I bought a set years ago and they work pretty well. The numbers were posted in the Stuff that Fits area but I haven't found them again lately. Maybe Ted can chase them down.
Posted 4 Years Ago
Last Active: 3 Weeks Ago
Gabriel G63398. I have them on mine too. Sand them down and spray black. can't tell from stock
bergmanj
Posted 4 Years Ago
Thanks, again,
 According to Gabriel, the G63398 shocks have been discontinued.
I also tried several sources on "The Web" which all said either unavailable or discontinued.
Anything else?
Regards, JLB
Posted 4 Years Ago
KG5429 KYB shocks. See Ebay for G63398 cross refence to KYB #. Check your local Parts Store for cross refence to other make Shocks.
fast freddy
Posted 4 Years Ago
Normally aspirated (49 reputation)Normally aspirated (49 reputation)Normally aspirated (49 reputation)Normally aspirated (49 reputation)Normally aspirated (49 reputation)Normally aspirated (49 reputation)Normally aspirated (49 reputation)Normally aspirated (49 reputation)Normally aspirated (49 reputation)
Last Active: 10 hours ago
Posts: 17, Visits: 8.3K
I had the same problem with Gabriels on the rear of my 55 wagon , I spoke to Gabriel about it and they recommended a AMC shock off of about 1973 hornet , done recall the number , It mounts the same but is 2 in longer extended .. I checked them out at rock auto and it seemed to be the correct extended length   hope this helps  Fred
