By bergmanj - 4 Years Ago
Folks, I have a question posted in "stuff that fits" regarding shocks: Please look and answer if you have information. Regards, JLB
A few replies: Thanks! I still need the extended length OEM length spec's. This affects ability to change tires/wheels when on car - without enough "drop" folks sometimes need to let air out of tires to get them off/on. I'm trying to avoid that situation - don't want to buy the "wrong" shocks. Thaks again, JLB
By MoonShadow - 4 Years Ago
I don't remember the specs but there are a set of front shocks for a Ford F150 that work. They operate in the same range but drop a couple inches further when jacked up. I bought a set years ago and they work pretty well. The numbers were posted in the Stuff that Fits area but I haven't found them again lately. Maybe Ted can chase them down.
By oldcarmark - 4 Years Ago
Gabriel G63398. I have them on mine too. Sand them down and spray black. can't tell from stock
Thanks, again, According to Gabriel, the G63398 shocks have been discontinued. I also tried several sources on "The Web" which all said either unavailable or discontinued. Anything else? Regards, JLB
KG5429 KYB shocks. See Ebay for G63398 cross refence to KYB #. Check your local Parts Store for cross refence to other make Shocks.
By fast freddy - 4 Years Ago
I had the same problem with Gabriels on the rear of my 55 wagon , I spoke to Gabriel about it and they recommended a AMC shock off of about 1973 hornet , done recall the number , It mounts the same but is 2 in longer extended .. I checked them out at rock auto and it seemed to be the correct extended length hope this helps Fred
