Cliff. Total agreement on the hardness. For lifters that have never been resurfaced before, the hardness is much more likely to be okay versus resurfacing lifters that have been previously resurfaced. There are some Y-Block tappet horror stories floating around in regards to resurfacing lifters that had been previously resurfaced. My thought process on resurfacing lifters is to only resurface lifters when new lifters of a suitable quality cannot be purchased. I’ve run both non-nitrided and nitrided new lifters with no issues either way. The cam lobes are always nitrided and that may be the saving grace for lifters that are not nitrided.
Visits: 190.0K
I purchased a new hayd lifter for a fe used the new lifter to set my angle, also the new lifter was not nitrated.,I compared the sparks for a hardness test. had a good idea re hardness from my ancent valve refacer,grinding a exhaust valve has different sparks and sound than a intake valve. not a very fool proof procedure . I purchased 4 lifters for a ford tractor engine, they are nitrited as well a grove for a snap ring so 1 would have a way to hold the lifter from falling out. they are identical to the y blocks, but very expensive.the face is the thin type for high lit cams.i used there thickness to determine how much to take off
Last Active: 6 hours ago
Visits: 13.9K
I'm going to buy a hardness tester soon, then I should know what I'm doing, as of now I think it's just to much of a gamble, I want to use FOMOCO Steel lifters (tappets) in some of my race engines, I've seen to many broken cast lifters for my taste.
Visits: 21.5K
Cliff, great find on that grinder, I just paid $200 for a set of tappets so if you can get the details worked out it may earn it's keep.
Visits: 190.0K
set my grinder with a new lift so the radius is as close as possible. have ground som damaged lifters and the finish shows a change, this is after.020, so I do not try to salvage 15 to 20%. I am very envious of the machine you found ,majer cam grinder hear does not have a tool like you do
Visits: 13.9K
There easy to find, just look for 10-15 years, ask everybody you think may have or know of one, read every book you can find, I found this in an auction of a VW engine rebuilding Co.in San Diego, CA, it was an internet auction, I bid it without seeing it (gamble).
Visits: 13.9K
Visits: 13.9K
