Visits: 57.3K
My 312 has the flat screw head and 5/8 locknut on the rocker arm. Trying to hold the screw steady while tightening the locknut is a real hassle as the screw always wants to turn just enough to throw the setting off. I wind up setting the lash wider trying to compensate for that little bit as I tighten the locknut. I saw real good video of a fellow adjusting valves on a Y-Block using just a feeler gauge and a socket style wrench, each valve took him a few seconds to set the lash. Does anyone know of this type of setup?
1955 312 T-Bird Warwick, NY
Visits: 23.2K
Google Summit Racing equipment, and type in valve lash adjusting tools. They have 38 different kinds listed. Joe-JDC
Visits: 57.3K
Hi Joe, I checked that out before posting; nothing for Y blocks.
Visits: 13.9K
Visits: 57.3K
Thanks but that’s not it either. A tool is only part of it, I’m talking screws and locknuts. Google “ How to adjust valves on a Ford Y Block “, you’ll see what I’m after. There’s a fellow doing a how to on a model A with a Y block.
Posts: 1.4K,
Visits: 2.0K
yblockguy.com/techtips/tech_tips.htm
Visits: 16.7K
I think the type of adjusters you are referring to that adjusted with a 1/2 socket, use an interference type thread, they do not require lock nuts.. I hate the ones your refer to as well. If they just had an allen head instead of a slotted screw it would work. You may be able to buy new or rebuilt rocker arms with that non lock nut adjuster
Visits: 498.2K
The interference type adjusters can be used with the rockers arms that use the nut, but due to the extra width of the nut type rocker it's close in setting the .019 lash. I had to replace a locking nut adjuster and the only one I had was an interference type. It worked, but real close in getting the required setting.
When setting lash with the nut type adjuster, I do, the same thing - leave it a tad loose to account for the adjuster to move.
Got a link to the video you mention? Adjusting the 1954-1956 rockers with the locknuts is similar to adjusting the valves with roller rocker arms which also have lock nuts. The only difference here is the oem rockers have a slotted screw adjuster versus the roller rocker arms using an allen wrench at the adjuster screw. Both types of rockers requires the lash to be a couple thousands loose to compensate for the adjuster moving slightly clockwise when tightening the lock nut. Once you get a handle on just how much to back up the adjuster screw to compensate for screw movement when tightening the lock nut, the process goes very quickly.
Visits: 22.0K
Here ya go, Ted.
Copy & paste to your search window.
