Valve lash adjustment
Posted By 312YBlock 5 Years Ago
312YBlock
Posted 5 Years Ago
Posts: 217, Visits: 57.3K
Great info as always. Thanks one and all 🚗
1955 312 T-Bird Warwick, NY
Posted 5 Years Ago
Here’s the link to a past discussion on this site about adjusting valves.  Does not cover the nuance about the adjuster screw moving as the lock nut is tightened but I did touch on that above.
http://forums.y-blocksforever.com/Topic8614.aspx
312YBlock
Posted 5 Years Ago
A good friend of mine and very knowledgeable told me about small block Chrysler solid lifter engines ie 273 318A 340 having allen head screws with locknuts. I found these on Summit Racing website. I believe these might be what I’m looking for.
Applications for CRN-99780-2 fits Chrysler 318
Crane Cams 99780-2 - Crane Shaft-Type Rocker Arm Adjusting Screws
( 1 ) Part Number: CRN-99780-2
62bigwindow
Posted 5 Years Ago
Posts: 884, Visits: 14.3K
Tim Mcmaster is the guy that post the video. He post two different methods of adjustment. I'm not sure if both videos have the interference fit set screws though.
Durham Missouri
Posted 5 Years Ago
I’ve adjusted the rockers countless times on our racing engines for the last 50 years. I’ll set the clearance with a screw driver or Allen slightly tight and hold that position with the screw driver or Allen and tighten the lock nut.  This usually loosens the clearance by a half a thousandths which is just right. I have never liked interference nuts or even stud rockers for that matter. On an off topic racing engine I purchased a T & D shaft system and can run a season of 6 to 8 races and never have them move; we turn that engine 7000 rpm at the end of every straightaway.
I find my y-block to hold its lash clearance consistently and rarely find one even a few thousandths off. I check them every oil change. I’ve watched Tim’s adjustment video and found it a good learning tool. Ted’s skill with y-blocks is also second to none.
If you having consistency problems with rocker arm lash I would be looking your oiling and the condition of the rocker bushings, shafts, and tips. Once a year I will run my engine with the rocker covers off and a cardboard shield to protect the exhaust manifolds to make sure the over flow tubes have oil flow. The left side seems to be a little quicker to flow than the right. My cardboard is wrapped with clear box tape. Good luck.
312YBlock
Posted 5 Years Ago
Thanks DLR 🚗
