vacum brake booster
Posted By trodom 4 Years Ago
trodom
Posted 4 Years Ago
Supercharged (91 reputation)Supercharged (91 reputation)Supercharged (91 reputation)Supercharged (91 reputation)Supercharged (91 reputation)Supercharged (91 reputation)Supercharged (91 reputation)Supercharged (91 reputation)Supercharged (91 reputation)
Posts: 29, Visits: 10.3K
in search of a vacum brake booster for 1958 ford f-600  thanks
Posted 4 Years Ago
Last Active: 48 minutes ago
Posts: 1.8K, Visits: 306.3K
The truck came through with differing style boosters as to what HYD brake  assy was installed.
Look at the ILL's. Yours should be a DIAPHRAGM TYPE mounted on the frame rail.
http://forums.y-blocksforever.com/uploads/images/d259eb0b-c9d4-4b23-b645-6f37.jpg
Look for an ASSY TAG or STAMPING NOS on the booster itself.
What type of problem are you having?
http://forums.y-blocksforever.com/uploads/images/1d30d665-6360-45ce-a11e-9691.jpg
trodom
Posted 4 Years Ago
mine is on the frame as in picture one   its been rebuilt  and still has a extreem hard pedel  will not work at all
Posted 4 Years Ago
Sounds like no vacuum assist. Have you checked engine manifold vacuum and the supply line being able to hold vacuum? The ILL shows the vacuum inlet off the engine manifold vacuum hose. There is a check valve there (2365). It may be bad. Using a vacuum gauge, check engine manifold vacuum and if good install a test tee at the booster vacuum inlet and see if the vacuum signal reaches the booster.
There is also an air filter used in the system (2363).
The hydraulics are in good shape, fluid clean and no frozen cylinders?
http://forums.y-blocksforever.com/uploads/images/e903ca40-f634-4c7f-932e-e6c3.jpg
cokefirst
Posted 4 Years Ago
Supercharged (375 reputation)Supercharged (375 reputation)Supercharged (375 reputation)Supercharged (375 reputation)Supercharged (375 reputation)Supercharged (375 reputation)Supercharged (375 reputation)Supercharged (375 reputation)Supercharged (375 reputation)
Posts: 152, Visits: 2.4K
Try Karps Power Brakes in Upland Ca.  He can probably help.  He has lots of rare and hard to find boosters and parts.
Posted 4 Years Ago
Posts: 3.6K, Visits: 497.7K
Google for Ford Trucks.  There is a site for old  Ford trucks and they may be able to help you.
