vacum brake booster
http://forums.y-blocksforever.com/Topic156732.aspx
By trodom - 5 Years Ago
in search of a vacum brake booster for 1958 ford f-600  thanks
By KULTULZ - 5 Years Ago
The truck came through with differing style boosters as to what HYD brake  assy was installed.
Look at the ILL's. Yours should be a DIAPHRAGM TYPE mounted on the frame rail.
http://forums.y-blocksforever.com/uploads/images/d259eb0b-c9d4-4b23-b645-6f37.jpg
Look for an ASSY TAG or STAMPING NOS on the booster itself.
What type of problem are you having?
http://forums.y-blocksforever.com/uploads/images/1d30d665-6360-45ce-a11e-9691.jpg
mine is on the frame as in picture one   its been rebuilt  and still has a extreem hard pedel  will not work at all
Sounds like no vacuum assist. Have you checked engine manifold vacuum and the supply line being able to hold vacuum? The ILL shows the vacuum inlet off the engine manifold vacuum hose. There is a check valve there (2365). It may be bad. Using a vacuum gauge, check engine manifold vacuum and if good install a test tee at the booster vacuum inlet and see if the vacuum signal reaches the booster.
There is also an air filter used in the system (2363).
The hydraulics are in good shape, fluid clean and no frozen cylinders?
http://forums.y-blocksforever.com/uploads/images/e903ca40-f634-4c7f-932e-e6c3.jpg
By cokefirst - 5 Years Ago
Try Karps Power Brakes in Upland Ca.  He can probably help.  He has lots of rare and hard to find boosters and parts.
By paul2748 - 5 Years Ago
Google for Ford Trucks.  There is a site for old  Ford trucks and they may be able to help you.
