Visits: 57.3K
My stock tachometer needle sits at 100 with the engine off. Does anyone know if that throws it off by 100?
1955 312 T-Bird Warwick, NY
Visits: 498.1K
Have you tried disconnecting the drive and see if it goes to zero? Maybe something in the cable.
Last Active: 37 minutes ago
Posts: 1.9K,
Visits: 195.0K
It's been a long time since I replaced the faceplate on my tach, nearly 20 years. But I don't remember the faceplate indexing to the gauge . I had to line it, the tach and the housing in the bezel to set the pointer at "0". Then redo it when I seated the bezel in the dash till I got it right. Jog anyone's else memory, or is this a foggy detail from another car?
FWIW, I didn't have the tach rebuilt, and it still reads within as close as you can tell with the rpm output the EFI shows. So it's accurate.
Visits: 113.5K
Indicating 100 rpm would be barely off the 0 mark. I would attach a good service tach and compare that to your original tach. + or - 100 rpm's is probably the the best these mechanical tachs will provide.
Posts: 1.4K,
Visits: 2.0K
Most tachs, whether electric or mechanical, are not dead-on accurate. Some are close, but others are way off. If you're within 100 rpm, regardless of road speed, I would say you're doing pretty well.
Visits: 6.7K
Not trying to throw off topic, but does the mechanical tachs in the early birds have a place to lube? Something similar to the speedometer head? Mine is making intermittent noise. Cable has been replaced and lubed correctly.
Kent — Round Rock, TX '56 F-100 | '56 Crown Vic | '57 Fairlaine 500 | '57 Thunderbird
Visits: 498.1K
Yes - it's at the top of the gauge if I remember correctly. May have to remove it to get at it. I had to. Use alight oil, like 3 IN 1 yblock57 (3/8/2021)
Visits: 6.7K
paul2748 (3/8/2021)
Yes - it's at the top of the gauge if I remember correctly. May have to remove it to get at it. I had to. Use alight oil, like 3 IN 1 Thank you sir!
