Visits: 497.9K
Info for a friend - Is a 239 Flywheel the same as 55 and 56 292-272
Last Active: 33 minutes ago
Posts: 7.5K,
Visits: 205.9K
Short answer is ‘Yes’. Looking at the parts manual, there are two basic standard transmission flywheels for the ’54-’59 Ford Y-Block engines. One is for the run of the mill models that has the pressure plate holes being on a 11 3/8” bolt circle. The other is the HD flywheel for the same year models having the pressure plate bolt holes located on a 12 3/8” bolt circle. Keep in mind that the 223/262 Ford six cylinder engines also use the same flywheels as the FYB.
Visits: 112.0K
A little off topic but when I first tore my Y block apart for rebuilding it had a flywheel with 12 holes drilled around the outer edge plus the standard holes for the pressure plate. At first I thought someone had tried to lighten it but after doing some research I found it was made for a boat.
Visits: 22.2K
the 239 used a 9.5 clutch.
Visits: 497.9K
Thanks all
