Visits: 3.4K
I do not know if I ever asked this question before but other then the carb what would be the difference between a 2 bbl vs 4 bbl 272,my 55 originally had the 4 bbl version but I stupidly sold it and trying to make one again but picked up a good running 55 2 bbl 272. Going to use the 57 intake and newer distributor and newer exhaust manifolds on this 272.
Visits: 323.4K
Compression ratio difference? 4barrel probably had higher compression.
Posts: 7.5K,
Visits: 205.9K
As John brings up, there is a compression ratio difference. The compression ratio for the 2V engine is 7.6:1 while the 182HP Special has a CR of 8.5:1. Early production 182HP Specials had ECL-6090-B cylinder heads while later production 182HP Specials had the ECG-6090-A heads. These are casting numbers and not part numbers.
