1955 272 2 bbl vs 4 bbl
http://forums.y-blocksforever.com/Topic154930.aspx
By junkyardjeff - 5 Years Ago
I do not know if I ever asked this question before but other then the carb what would be the difference between a 2 bbl vs 4 bbl 272,my 55 originally had the 4 bbl version but I stupidly sold it and trying to make one again but picked up a good running 55 2 bbl 272.  Going to use the 57 intake and newer distributor and newer exhaust manifolds on this 272.
Compression ratio difference?  4barrel probably had higher compression.
By Ted - 5 Years Ago
As John brings up, there is a compression ratio difference.  The compression ratio for the 2V engine is 7.6:1 while the 182HP Special has a CR of 8.5:1.  Early production 182HP Specials had ECL-6090-B cylinder heads while later production 182HP Specials had the ECG-6090-A heads.  These are casting numbers and not part numbers.
