Hurst Mystery Shifter
Posted By Tim Quinn 6 Years Ago
Tim Quinn
Posted 6 Years Ago
Supercharged (633 reputation)Supercharged (633 reputation)Supercharged (633 reputation)Supercharged (633 reputation)Supercharged (633 reputation)Supercharged (633 reputation)Supercharged (633 reputation)Supercharged (633 reputation)Supercharged (633 reputation)
Posts: 266, Visits: 3.5K
"EASIER WITH THE RIGHT PARTS" make me think twice about a floor shifter.
Thanks,
Tim
Some Place, Fl
33706
Tim Quinn
Posted 6 Years Ago
Thanks for your input, I'll look into that site
Happy New Year in 2021
Tim
Downtown, Fl,
33606
57RancheroJim
Posted 6 Years Ago
Posts: 729, Visits: 112.0K
I modified the bracket and arms to fit the light duty OD in my 60 truck. I looked for one for the T85 in my Ranchero and the only one I could locate was selling for $800, it was new. I decided I like the three on the tree..
Daniel Jessup
Posted 6 Years Ago
Last Active: Today @ 1:57:22 AM
Posts: 2.0K, Visits: 131.0K
Tim,
I went through this ordeal when swapping out my old Fordomatic with a 3 speed R10 OD in my 55 Club Sedan. Some of those blog posts can be found at these links: https://www.hotrodreverend.com/blog/categories/transmission
also, one seller on eBay that seemed to be quite knowledgeable and was a real help in locating the parts at the right prices was this guy:
https://www.ebay.com/usr/4ever4d?_trksid=p2053788.m1543.l2754
Daniel Jessup
Lancaster, California
Posted 6 Years Ago
Posts: 1.9K, Visits: 194.9K
Tim, I had a Mystery Shifter on a T-86 o/d behind a 352 in a 59 bird. (It was so tired I didn't break the trans) and a Syncro Lock on a T-85 o/d in a 55 bird. Both requires some bracket and rod modifications. This was back in the 60's when they were still in the catalog.
There's two old sayings about the Mystery Shifter. "It's a mystery how we made it so affordable" and "it's a mystery what gear your in".
Other than the price it's only advantage was you could cut the stick off to the length you wanted. I had a speed shop that worked with me, and they ordered the T-85 o/d brackets and a Corvette (short stick), which is what went in the 55 bird.
If you end up making the brackets and rods (which isn't all that big a deal if the main bracket fits the trans/bell mount) find a Syncro lock to start with. It's got the adjustable stops and a far better unit. If you are a welder it's just a pita with the trans in the car. But you'll get a much better result. I made mine with machine screws, then had the whole works welded up. I was 17 then.
Tim Quinn
Posted 6 Years Ago
Ted,
I do that all the time......typeo errors.....confusing names etc.
Tim
Warmer today,
Florida, 33706
Posted 6 Years Ago
Posts: 7.5K, Visits: 205.9K
Tim Quinn (12/28/2020)
Ted,
The shift kit I'm looking at is #5262 not #8252.
Tim
Tim.  That was a typo on my end.  I did look for the 5262 number but nothing came close.
Tim Quinn
Posted 6 Years Ago
Ted,
Tim
Central, Fl
33705
slumlord444
Posted 6 Years Ago
Posts: 1.2K, Visits: 137.8K
My experience with the Hurst shifter in the past was the shifter itself was the same. The mounting brackets and shift rods were different for different applications. I was able to modify the bracket and shift rod to fit. Easier to have the right parts but it can be done.
Posted 6 Years Ago
In looking thru a 1970 Hurst shifter catalog, that ‘M/S FO 5262 part number does not match up to any of the listings.  In looking at that particular catalog, the O/D transmissions do have different Mystery Shifter part numbers than what’s listed for the non O/D Ford transmissions.  For the O/D transmissions, there are even different part numbers for the Ford versus the BW transmissions.
