Hurst Mystery Shifter
http://forums.y-blocksforever.com/Topic154354.aspx
By Tim Quinn - 6 Years Ago
Will the Hurst Shifter # M/S FO 5262  fit my '56 Ford with overdrive ?  Will the O/D solenoid be in the way?
Thanks in advance
Tim
Central, Florida
33706
There’s a Hurst Mystery shifter for a 52-56 Ford on E-bay right now that’s a FO 5252. I should ask the seller if it shows in the instructions if THAT one fits an overdrive. I wouldn’t tell him what you have. A 5262 might be the correct on for an OD if he says his will not fit an OD....
I did contact him . His answer was not good enough, so I decided to post on Y-Blocks Forever.
Thanks for your get back,
Tim
North Pole, Florida
very cold here
By Ted - 6 Years Ago
In looking thru a 1970 Hurst shifter catalog, that ‘M/S FO 5262 part number does not match up to any of the listings.  In looking at that particular catalog, the O/D transmissions do have different Mystery Shifter part numbers than what’s listed for the non O/D Ford transmissions.  For the O/D transmissions, there are even different part numbers for the Ford versus the BW transmissions.
By slumlord444 - 6 Years Ago
My experience with the Hurst shifter in the past was the shifter itself was the same. The mounting brackets and shift rods were different for different applications. I was able to modify the bracket and shift rod to fit. Easier to have the right parts but it can be done.
Ted,
The shift kit I'm looking at is #5262 not #8252.
Thanks for your input,
Tim
Central, Fl
33705
Tim Quinn (12/28/2020)
Ted,
Tim
Tim.  That was a typo on my end.  I did look for the 5262 number but nothing came close.
Ted,
I do that all the time......typeo errors.....confusing names etc.
Tim
Warmer today,
Florida, 33706
By miker - 6 Years Ago
Tim, I had a Mystery Shifter on a T-86 o/d behind a 352 in a 59 bird. (It was so tired I didn't break the trans) and a Syncro Lock on a T-85 o/d in a 55 bird. Both requires some bracket and rod modifications. This was back in the 60's when they were still in the catalog.
There's two old sayings about the Mystery Shifter. "It's a mystery how we made it so affordable" and "it's a mystery what gear your in".
Other than the price it's only advantage was you could cut the stick off to the length you wanted. I had a speed shop that worked with me, and they ordered the T-85 o/d brackets and a Corvette (short stick), which is what went in the 55 bird.
If you end up making the brackets and rods (which isn't all that big a deal if the main bracket fits the trans/bell mount) find a Syncro lock to start with. It's got the adjustable stops and a far better unit. If you are a welder it's just a pita with the trans in the car. But you'll get a much better result. I made mine with machine screws, then had the whole works welded up. I was 17 then.
Tim,
I went through this ordeal when swapping out my old Fordomatic with a 3 speed R10 OD in my 55 Club Sedan. Some of those blog posts can be found at these links: https://www.hotrodreverend.com/blog/categories/transmission
also, one seller on eBay that seemed to be quite knowledgeable and was a real help in locating the parts at the right prices was this guy:
https://www.ebay.com/usr/4ever4d?_trksid=p2053788.m1543.l2754
By 57RancheroJim - 6 Years Ago
I modified the bracket and arms to fit the light duty OD in my 60 truck. I looked for one for the T85 in my Ranchero and the only one I could locate was selling for $800, it was new. I decided I like the three on the tree..
Thanks for your input, I'll look into that site
Happy New Year in 2021
Tim
Downtown, Fl,
33606
"EASIER WITH THE RIGHT PARTS" make me think twice about a floor shifter.
Thanks,
Tim
Some Place, Fl
33706
