Fordomatic help requested ('57 thunderbird)
Posted By yblock57 6 Years Ago
Lord Gaga
Posted 6 Years Ago
Last Active: 10 Months Ago
Posts: 470, Visits: 183.3K
Thanks for the great description and videos Kent!
"FREE SAMPLE"
2721955meteor
Posted 6 Years Ago
Posts: 927, Visits: 190.0K
years ago put my govoner in backwerds, woud not shift into high atall,turned around worked ok. if you do eventualy int high ,it was in corectly
stickey or gasket incorect
2721955meteor
Posted 6 Years Ago
my screwup was a 57merc and removed tailshaft and turned the whole asemblyaround,was my1st crack at a auto trans,that worked,found out later could axcess threw the cover,tho in my case just turning govener may not have worked
FORD DEARBORN
Posted 6 Years Ago
Posts: 852, Visits: 113.5K
Great work, you nailed it.............
yblock57
Posted 6 Years Ago
Supercharged (271 reputation)Supercharged (271 reputation)Supercharged (271 reputation)Supercharged (271 reputation)Supercharged (271 reputation)Supercharged (271 reputation)Supercharged (271 reputation)Supercharged (271 reputation)Supercharged (271 reputation)
Posts: 99, Visits: 6.7K
While I'm waiting on my valve body part, I wanted to try to get the linkage set the best possible by the book. I can't get the accelerator pedal height up past 3" and the book calls for 4 7/8" on a '57 thunderbird.
As a consequence of this, when you floor the pedal, you do not get full throttle engagement. When you work the 'grasshopper' under the hood by hand to full throttle, the rod pops out of the back of the accelerator pedal. Obviously there's something wrong here.
I've locked the 'grasshopper' in place with the 1/4" drill bit and the threaded rod that sets the pedal height is extended as long as it will go. 3" is all I can get out of the adjustment.
I went ahead and removed the piece of linkage from the accelerator pedal that goes through the firewall and measured and took a few pics. If anyone has one I can compare mine to, that would be great. Not sure if the curve in it is correct or not — it doesn't appear bent to the naked eye. I don't want to flatten that curve in a vise if it is indeed correct and the problem is elsewhere. Tip to tip is 5 7/8"
http://forums.y-blocksforever.com/uploads/images/d7eac264-773b-4c27-8f85-8cef.jpg
http://forums.y-blocksforever.com/uploads/images/147a0d6e-3daa-47c6-8529-1e55.jpg
http://forums.y-blocksforever.com/uploads/images/21515eab-1c94-4b54-803c-2fe6.jpg
http://forums.y-blocksforever.com/uploads/images/89338a0b-023d-49bf-a566-6aca.jpg
Nothing else in the setup looks bent or twisted.
Thanks!
Kent — Round Rock, TX
'56 F-100  | '56 Crown Vic  |  '57 Fairlaine 500  |  '57 Thunderbird
Posted 6 Years Ago
Last Active: 4 minutes ago
Posts: 3.8K, Visits: 33.3K
What did You need for  the Valve Body?
yblock57
Posted 6 Years Ago
oldcarmark (10/30/2020)
Forgot to update. I made an error in filing off that 'tab' on the end plate that was blocking the throttle valve. According to the book, (which I missed) you're supposed to push the valve out past the first land then install the plate. It acts as a stop to keep the valve from over travel and prevents it from fulling returning inside the valve body. Amateur mistake.
Luckily, Dad has a couple extra in his parts stash that we can scavenge. I'll be sure to update the thread once corrected and installed for future reference.
In the meantime, Getting the accelerator pedal height correct and having everything in the linkage work as it should is my next hurdle.
If anyone has another threaded rod they could check total length when fully extended, that would help me a ton. Mine measures 5 1/4"
http://forums.y-blocksforever.com/uploads/images/9d25e512-4415-47d6-83fc-c20.jpeg
If this is too short and incorrect for a '57 thunderbird, that would explain the issue. If not, looks like I'll end up having to 'tweak' my firewall rod.
Thanks!
Posted 6 Years Ago
1/4x20 rod and coupling from a hardware store like ACE can help. It’s how I made the carb linkage when I change to 2 carbs. Good luck
yblock57
Posted 6 Years Ago
After looking at pics on here and my friend's '57 and comparing setups, the conclusion was my double-L rod on the firewall was bent... slightly. I removed it from the car and mounted it on my workbench. Was expecting a battle to get any bending action, but it moved surprisingly easy.
http://forums.y-blocksforever.com/uploads/images/49515883-82de-48b1-87df-2df9.jpg
Got lucky as I bent it it just the right amount the first time. Verified 4 7/8" pedal height with the 1/4 drill bit in the bell crank. Adjusted the rod going to the carburetor and presto — everything works as advertised. No more binding, and I get full throttle with the pedal — at least everything up top is moving the way it should... we'll see how it goes with the throttle rod once the valve body goes back in.
Now it's just a matter of getting the valve body back in the transmission and verifying throttle rod travel and getting pressures set correctly.
Thanks to all who've chimed in and helped. I'll keep y'all posted on how this turns out.
Posted 6 Years Ago
Any new Updates?
