Visits: 147
My 1955 Ford Crown has a 5 stud wheel but what is the bolt pattern size for this car..John jdhenrhy833@aol.lcom
JDH: 1955 Ford car, I have switched from 6 volts to 12 volts. Every thing working on 12 volts except now I have no brake lights, no turn signals. I have 12 volts at the brake cylinder. Where have I gone wrong? Turn signals worked on right hand side of car for a short time but quit.
Last Active: 1 hour ago
Posts: 3.6K,
Visits: 497.7K
The lug pattern is 4 1/2 X 5 . Ford has used this pattern for many years since 1949. Early Merc's are different (5 X 5). Pickup trucks used a 5 1/2 X 5 since before 1949, but later changed the pattern. Not sure what they are now.
Visits: 1.8K
Chrysler products also 5 x 4 1/2.
Visits: 22.2K
ford from 73 to 78 used a gm bolt pattern.on their big cars only same as gm 1/2 tons and some full size cars.
Did you change the flasher. Check the fuse feeding it. Good luck.
