1955 Ford Fairlane Wheel bolt pattern?
http://forums.y-blocksforever.com/Topic153346.aspx
By johns55ford - 5 Years Ago
My 1955 Ford Crown has a 5 stud wheel but what is the bolt pattern size for this car..John jdhenrhy833@aol.lcom
By paul2748 - 5 Years Ago
The lug pattern is 4 1/2 X 5 .  Ford has used this pattern for many years since 1949.  Early Merc's are different (5 X 5).  Pickup trucks used a 5 1/2 X 5 since before 1949, but later changed the pattern.  Not sure what they are now.
By 55blacktie - 5 Years Ago
Chrysler products also 5 x 4 1/2.
By darrell - 5 Years Ago
ford from 73 to 78 used a gm bolt pattern.on their big cars only same as gm 1/2 tons and some full size cars.
Did you change the flasher. Check the fuse feeding it. Good luck.
