Petronix ignitor III and flame thrower coil vs Tach
Posted By Lawrence Petty 6 Years Ago
Lawrence Petty
Posted 6 Years Ago
Supercharged (76 reputation)Supercharged (76 reputation)Supercharged (76 reputation)Supercharged (76 reputation)Supercharged (76 reputation)Supercharged (76 reputation)Supercharged (76 reputation)Supercharged (76 reputation)Supercharged (76 reputation)
Posts: 28, Visits: 5.9K
Can't find out what aftermarket tach will work with the Petronix Ignitor III and coil in my Ford 292 Y-block.  Have looked on line and can't find a straight answer.  Is someone running a tach that works that can advise me what to buy?
slumlord444
Posted 6 Years Ago
Last Active: 5 Months Ago
Posts: 1.2K, Visits: 137.8K
sun works fine with mine
Posted 6 Years Ago
Posts: 3.7K, Visits: 498.3K
Have you talked to Pertronix on your question?
Posted 6 Years Ago
The information you are seeking should be found on the Pertronix website and included with the Pertronix lll. It should be compatible with any electric tach.
Talkwrench
Posted 6 Years Ago
Posts: 898, Visits: 23.2K
Mine seems ok with a Moon tach [modern] . However I would never recommend the Moon tach
Posted 6 Years Ago
Autometer, and Pertronix. Works with points or Electronics.
Posted 6 Years Ago
Posts: 1.2K, Visits: 285.6K
Talkwrench (9/8/2020)
I have a modern Moon Tach in my TBird.  Looks great and works with my Pertronix One Unit and Flamethrower coil.
http://forums.y-blocksforever.com/uploads/images/5e0edd63-3769-48b4-a9d7-0ca1.jpg
Posted 6 Years Ago
This one is currently sold thru Summit. It’s has listed Bosch as the manufacturer but I’m sure it’s overseas to the west. It’s appearance was what I wanted and accuracy is difficult because of the 8K max. However the calculations at 60 is correct. The ignition is a Pertonix II.
