Petronix ignitor III and flame thrower coil vs Tach
http://forums.y-blocksforever.com/Topic153210.aspx
By Lawrence Petty - 6 Years Ago
Can't find out what aftermarket tach will work with the Petronix Ignitor III and coil in my Ford 292 Y-block.  Have looked on line and can't find a straight answer.  Is someone running a tach that works that can advise me what to buy?
By slumlord444 - 6 Years Ago
sun works fine with mine
By paul2748 - 6 Years Ago
Have you talked to Pertronix on your question?
By 55blacktie - 6 Years Ago
The information you are seeking should be found on the Pertronix website and included with the Pertronix lll. It should be compatible with any electric tach.
By Talkwrench - 6 Years Ago
Mine seems ok with a Moon tach [modern] . However I would never recommend the Moon tach
By pegleg - 6 Years Ago
Autometer, and Pertronix. Works with points or Electronics.
By Florida_Phil - 6 Years Ago
Talkwrench (9/8/2020)
I have a modern Moon Tach in my TBird.  Looks great and works with my Pertronix One Unit and Flamethrower coil.
http://forums.y-blocksforever.com/uploads/images/5e0edd63-3769-48b4-a9d7-0ca1.jpg
This one is currently sold thru Summit. It’s has listed Bosch as the manufacturer but I’m sure it’s overseas to the west. It’s appearance was what I wanted and accuracy is difficult because of the 8K max. However the calculations at 60 is correct. The ignition is a Pertonix II.
