NEW Holley Slayer Series Carb 450CFM VS
Posted By Rudder2fly 5 Years Ago
Rudder2fly
Problem Posted 5 Years Ago
Supercharged (361 reputation)Supercharged (361 reputation)Supercharged (361 reputation)Supercharged (361 reputation)Supercharged (361 reputation)Supercharged (361 reputation)Supercharged (361 reputation)Supercharged (361 reputation)Supercharged (361 reputation)
Posts: 160, Visits: 35.5K
I need suggestions on my pop back thru carb coming off idle with FOM in drive? MSD 8383 Dist with 12 degrees advance, ISKY E-2 cam at 17 degrees crankshaft advance, Fuel pressure not within Holley spec of 6-6 1/2 # I am at 3-4 # with mechanical pump. Fuel levels in site glass at idle are where they are suppose to be. Idle RPMS set a little high at 900 since this is a A/C car. I have taken all the slack out of carbhttp://forums.y-blocksforever.com/uploads/images/75473a14-67b6-44ce-979b-b343.jpg pump arm. Motor does not diesel on shut down. The low speed set screws are responsive and set 1/2 turn out at 16 in. of vacuum. Engine in good condition as has fresh rebuild. Carb is excellent once off idle and at Hwy speeds. Holley Part # SL-450-VS.
56 VIC  Gene Stoehr Sr.
Cliff
Posted 5 Years Ago
Posts: 878, Visits: 13.5K
That carb is a little small, you need to work on the accelerator pump curve, a 3310 Holley is a better choice
Posted 5 Years Ago
"Holley Slayer" ?!  What is that?  Is that a reference to a  Summit carb or?
Rudder2fly
Posted 5 Years Ago
Holley touts this new Quick Fuel Technology. Made in Bowling Green Ky. Go to their web site and check the part number. All I can say the motor pulls as hard as any Y-Block I have ever owned. I like it!!!
Rudder2fly
Posted 5 Years Ago
I will work on pump delivery. I was thinking not enough fuel might be the problem.
62bigwindow
Posted 5 Years Ago
Posts: 884, Visits: 14.3K
With your combo the 450 sounds a little small. My engine is similar to yours and I'm running a Quick Fuel Sl-1957e 600 cfm. I'm far from a expert but it sounds like it may be a lean issue. Have you looked at your plugs?
Durham Missouri
Lord Gaga
Posted 5 Years Ago
Posts: 464, Visits: 183.3K
Is your cam really at 17 deg. advance? You degreed it? That's your problem I'd say.
"FREE SAMPLE"
Rudder2fly
Posted 5 Years Ago
Isky called for 15 1/2 degrees advance was 1/2 under and I added 2 degrees to put the cam at 17. Per degree wheel.
Rudder2fly
Posted 5 Years Ago
Haven't done the plug check. Just removed a 3X2 set up that I finally got tired of tweaking so would have to change plugs for a better look.
Posted 5 Years Ago
Posts: 6.1K, Visits: 442.8K
Could you have misunderstood ignition advance for cam advance?
