1957 fairlane 500 stock 292 cam specs
Posted By dgmford 5 Years Ago
dgmford
Question Posted 5 Years Ago
Normally aspirated (25 reputation)Normally aspirated (25 reputation)Normally aspirated (25 reputation)Normally aspirated (25 reputation)Normally aspirated (25 reputation)Normally aspirated (25 reputation)Normally aspirated (25 reputation)Normally aspirated (25 reputation)Normally aspirated (25 reputation)
Posts: 7, Visits: 15
does anyone know what the stock cam duration and lift would be?
thanks
DGMFORD
1955 F100
1957 Ford Fairlane 500
This post has been flagged as an answer
Posted 5 Years Ago
http://forums.y-blocksforever.com/uploads/images/698ef50b-e6b8-4575-acd4-03c9.jpg
2721955meteor
Posted 5 Years Ago
Posts: 927, Visits: 190.0K
question. i have a cam grinder that tells me the 1957 merc 312 had a different grind is that true or falce
thanks cliff t
dgmford
Posted 5 Years Ago
thank you!!
DGMFORD
1955 F100
Posted 5 Years Ago
2721955meteor (8/17/2020)
thanks cliff t
Camshafts were the same for the 1957 Ford and Mercury 312.
darrell
Posted 5 Years Ago
Posts: 455, Visits: 22.2K
were the 1.54 rockers really 1.54 most say not.
2721955meteor
Posted 5 Years Ago
THANKS
Posted 5 Years Ago
darrell (8/18/2020)
Were the 1.54 rockers really 1.54?  Most say not.
One factor that affects the rocker ratio is the valve train geometry.  The rocker arm shafts being higher or lower than ideal has the net effect of reducing the valve lift which results in a reduced rocker ratio.  Another factor is where the adjuster rests within the rocker arm when the tappet clearance is properly adjusted.  Push rod length is the determining factor for that.  Here are some ratio numbers from a past article on the subject originally published in The Y-Block Magazine.
 http://forums.y-blocksforever.com/uploads/images/98cd9e02-c7a1-415a-bbb5-7d5c.jpg
And here’s the link to the original article.
https://www.eatonbalancing.com/2007/12/10/altering-rocker-arm-ratio-by-varying-the-length-of-the-pushrods/
