1957 fairlane 500 stock 292 cam specs
Home
Keeping The Dream Alive!
Technical
http://forums.y-blocksforever.com/Topic152944.aspx
Print Topic
Close Window
By dgmford
4 Years Ago
does anyone know what the stock cam duration and lift would be?
thanks
By Ted
4 Years Ago
By 2721955meteor
4 Years Ago
question. i have a cam grinder that tells me the 1957 merc 312 had a different grind is that true or falce
thanks cliff t
By dgmford
4 Years Ago
thank you!!
By Ted
4 Years Ago
2721955meteor (8/17/2020)
thanks cliff t
Camshafts were the same for the 1957 Ford and Mercury 312.
By darrell
4 Years Ago
were the 1.54 rockers really 1.54 most say not.
By 2721955meteor
4 Years Ago
THANKS
By Ted
4 Years Ago
darrell (8/18/2020)
Were the 1.54 rockers really 1.54? Most say not.
One factor that affects the rocker ratio is the valve train geometry. The rocker arm shafts being higher or lower than ideal has the net effect of reducing the valve lift which results in a reduced rocker ratio. Another factor is where the adjuster rests within the rocker arm when the tappet clearance is properly adjusted. Push rod length is the determining factor for that. Here are some ratio numbers from a past article on the subject originally published in The Y-Block Magazine.
And here’s the link to the original article.
https://www.eatonbalancing.com/2007/12/10/altering-rocker-arm-ratio-by-varying-the-length-of-the-pushrods/
