1957 292 - transmission options in a '54 Merc
Posted By mars54 6 Years Ago
darrell
Posted 6 Years Ago
Posts: 457, Visits: 22.3K
you can use a fordomatic bell in place of the c4 bell.the fordo bell will almost fit over the c4 pump but the opening is a little small you have to open it up about 1/8 inch.i done a rough mockup once.than make a pattern and drill the 7 bolt holes and bolt it on.use a com flywheel your getting close.from what i can see the torque converter will sit back to far from the flywheel.just some minor things.there may be other problems as i said i never tried to finish one.
cokefirst
Posted 6 Years Ago
Supercharged (393 reputation)Supercharged (393 reputation)Supercharged (393 reputation)Supercharged (393 reputation)Supercharged (393 reputation)Supercharged (393 reputation)Supercharged (393 reputation)Supercharged (393 reputation)Supercharged (393 reputation)
Posts: 159, Visits: 2.4K
I have a vague understanding of the workings of an automatic transmission but I have never torn one apart and am not familiar with the differences in one model to the next.  I would like to ask a stupid question.  Since the early Fordomatic is technically a 3 speed unit, it there anyway of changing the internals so that it works as a 3 speed, starting in low instead of starting in second?
Posted 6 Years Ago
D.L. Racer: not sure I understood your reply?.. Anyway, if I have the info correct, (?) when the C series transmissions came on the market, the Fordo was reduced to a 2 spd, like a G.M. Power Slide  for 1959..  But, I've never driven a 1959 Fordomatic, so I don't have direct experience with it..
Posted 6 Years Ago
Posts: 3.7K, Visits: 323.6K
Cokefirst, yes you can do what you asked, and by the way there are no stupid questions if they are asked in sincerity. You will need a donor FMX transmission.  You need the valve body and "rooster tail" detent, and to drill and tap the back of the case to accept the vacuum modulator.  If your present transmission does not have a ne-way clutch (sprag) in the center of the transmission drive train then you will have to swap that also.  It would be a good idea to use the FMX pressure regulator as well.  I hear that you can also use the parts from a Cruisomatic with the double drive range on the shifter and vacuum modulator.  In either case, your shift lever may have to be modified to allow enough travel for the extra gear position, or you can leave it alone and not have a manual low gear position.  Other options would be to use the dual range Cruiso transmission complete or adapt the FMX to your bellhousing and converter and use it pretty much "as is".  The FMX swap is more involved than the Cruiso swap.
Posted 6 Years Ago
Hoosier: needs to look like this when your done. The Drive detent in the column needs to be bigger by about 1/8” for 2 positions now; this was done by a die grinder and a file after the steering wheel is off and the turn signal unit is laid out.
Last the column shift arm needs to be longer 7/8-1”.
As a final thing. The “park” on the transmission arm from the internals does not have a detent like R-N-D1-D2-L; you push up your shifter arm (column or floor) and it has the slot to keep it in park. Ford has had problems over the years and with the steering wheel off along with the turn signal mechanism you can really see this.
Posted 6 Years Ago
DLR, that's ingenious and well done.  Beautiful!
chris70
Posted 6 Years Ago
Posts: 41, Visits: 50.1K
Hello everybody,i have a COM trans in my truck,the one that starts in second when you put in drive and strats in first when put in second,did i get it right that by changing the valve body with one off an FMX from 1967 or later it will shift like a C4?
Thanks Christian
Posted 6 Years Ago
Chris, the FMX valve body and detent will cause it to take off in low, shift to 2nd, then shift to 3rd.  If your trans has no vacuum modulator, you will have to drill and tap the case and install a modulator.
chris70
Posted 6 Years Ago
My transmission already has the vacuum modulator and cooling lines,so schould it be a simple swap of the valve bodies? I have to ask what the "detent" is?
Posted 6 Years Ago
The detent is commonly called the "rooster comb".  It is a notched plate controlled by the shift lever and located inside the trans.  Its notches actuate a spring loaded bearing ball to hold the control valve in its proper location.  I always thought the dual range cruisos with the dual "drive" selection on the shifter took off in 2nd and shifted to third in one position and took off in 1st, shifted to 2nd and then shifted to 3rd in the other position.  I could be wrong.
