dennis22
Visits: 59.7K
Hi everyone, I’ve been doing a bit of reading about different intake performance and have decided to modify my B intake to a dual plane. My questions are- 1- should I open up the 4 holes radius larger to suit the spacer I have? (See below photo with marker) 2- should I machine the top surface flat or leave the factory depression?
Thanks, Dennis.
56 F100 - 272 Y Block NSW, Australia.
Visits: 206.1K
Joe-JDC
Visits: 23.3K
This modification also allows the use of a phenolic spacer to keep the carburetor cooler and helps prevent fuel percolation. Joe-JDC
dennis22
Visits: 59.7K
Thanks Ted and Joe. In this instance I’ll go for the 4 bbl spacer, but hypothetically if I were to go for the dual plane modification on the manifold, would I machine the surface flat an open the holes up slightly?
Thanks, Dennis.
The manifold is already dual plane. Modifying it as Ted shows makes it work better and accommodate larger, modern carbs while maintaining dual plane functionality. You can machine it flat. Others have used epoxy to fill in the valley in order to make it flat. The holes should be opened up to match the carburetor, at the very least.
dennis22
Visits: 59.7K
I realize it already a dual plane manifold. Ok so I just want to clarify, please correct me if I’m wrong- machine the 2 slots in the manifold but use a 4 hole spacer to retain the low end torque, correct?
Thanks, Dennis.
The spacer should be 4 hole or divided (2 ovals) in order to maintain the dual plane functionality. Here are some examples. The one in the middle is a hybrid of the two, two ovals on bottom, 4 hole on top.
dennis22
Visits: 59.7K
Nice one, thanks. I have ordered a 2inch 4hole spacer and will get the manifold machined. Thanks Everyone for the advice, much appreciated!
Thanks, Dennis.
Talkwrench
Visits: 23.2K
1946international
Visits: 21.5K
Great info here, I think I'll try milling out the two slots. Thanks for the info.
